  • Member For: 21y 1m 29d
  XR8Rob said:
that's great to hear! Forgot to ask at the time, but was the 10.92 and also is your current tune benefiting from the recent breakthough with torque tables on the ZF
My car hasn't been programmed with the new launch software yet. But will soon. Considering I only had one pass doing a normal 1st gear stall up not the 2nd to 1st technique I've been using before I think there is more in the package without the software.
  senna_T said:
so when do you go and beat that "slow" 10.92 quarter??? :buttrock:
Hopefully very soon :spoton:
Just been very lazy lately.
  • Member For: 17y 8m 13d
  _XRQTOR_ said:
Where do I order a 32 model from, 1ooonm from the facotry :gooff: . Imagine what it'd take once it got a tickle.
I can remember reading a long time ago something about one of the ZF trans and that with the paddle shift fitted (doable with ours) that it actually stabs the throttal on downshifts, is this the 32 that does this or another version. The article said the version of zf trans would appear in a falcon anytime soon as it was over kill for our application.
A friend of mine has the BMW X5 with the M5 motor etc. For a big beast, it moves. The transmission is unbelieveable. Smooth and smart. Brake hard from a high speed and it blips the throttle as it down shifts at around 3500 rpm from memory. Very manual like...would be a real nice addition to any car.
  • Tractor Driver
  • Member For: 19y 2m 21d
Jags and Audis with the ZF transmissions do that too ... why couldn't Ford have that programmed into the PCM??? :roflmbo:
  • Forged Member
  • Member For: 18y 2m 24d
I think it has something to do with the responsiveness of the throttle bodies used in the falcon engines, someone correct me if I'm wrong
  • 5 weeks later...
  • 2 weeks later...
The problem isn't the ecu itself but the software that runs it, ZF won't hand you thir software program pat you on the back and say have fun. I would think the only way to get one to work would be to run a ecu from a car that has one fitted and hope there's good editing software for it.
  • Member For: 17y 8m 3d
I had hoped there was another way--the only cars I have found with the 6hp32 are bmw's or the rolls' phantom (owned by bmw) and from what I know (which again is not much about the electronics side) trying to customize the ecu form one of those cars on a ford engine would be not likely, if possible (those engines are both v12's). Anyone know of any other semi-auto transmissions that could bolt up to the 5.4 motor and handle 370kW/500ftlb? I'm trying to think of ideas for a sports car that can be driven on the track and take me to work comfortably.
  • Member For: 18y 9m 12d
Mine has done 23000 clicks with 370 rwkw and now many track runs with 400 and she is still as good as new. (should never say these comments)
