F6BF Member 438 Member For: 19y 4m 18d Location: Sydney Posted 15/05/07 06:02 AM Share Posted 15/05/07 06:02 AM Mauz like others have mentioned give Dave at Kewish a call, he is modifing the valve bodys which improves the shifts and the clamping force of the clutch packsHe has also fitted a higher stall converter in them, but restricted to only 2500 rpm any more than that trans sensors slip and goes into limp modeI will be getting him to do mine soon Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532708 Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 9m 25d Location: Rolling on my 20's Posted 15/05/07 06:07 AM Share Posted 15/05/07 06:07 AM Jim I might do mine with you as Dave may do us a deal. Is Dave doing a complete package with all improvements or is it 'ain't broke don't upgrade it'? Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532709 Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 4m 18d Location: Sydney Posted 15/05/07 06:15 AM Share Posted 15/05/07 06:15 AM F6_Tornado said: The cooler won’t help you one bit apart from keeping the oil cool on low HP vehicles.You don’t need to have hot oil to Snap the input shaft. Just lots of HP. So to me unless you do track work, the original cooler is fine. neither will save your input shaft.Bigger aftermarket cooler will keep trans temps down saving the oil from burning resulting in less oil changes also stops internal seals from going hard.....huge benefit to the trans as alot of the zfs are overheating and glazing the clutch packs Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532711 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 22d Location: In The Ute Posted 15/05/07 06:20 AM Share Posted 15/05/07 06:20 AM Here are some pics of some ZF parts out a F6’s that I’ve had the pleasure of rebuilding for a mate. I don’t do it for a living and have only helped mates.Notice the bar-code on the input shaft and how twisted it is? They usually snap about ½ way through where the bar-code is.This one is snapped and sat back together to show the twist.This one is just twisted but not snapped.This is the new heat treated input shaft.These Discs are typical worn discs but they are cheap. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532713 Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 4m 18d Location: Sydney Posted 15/05/07 06:23 AM Share Posted 15/05/07 06:23 AM Billsta said: Jim I might do mine with you as Dave may do us a deal. Is Dave doing a complete package with all improvements or is it 'ain't broke don't upgrade it'?Will talk to Dave see what he can do for us coming from sydneyWill do the valve body and trans cooler for sure dont know about the converter as we still wont be able to spool up boost due to trans module cannot be edited yetThanks for the pics mateIs the new input shafts now all heat treated or is someone doing them aftermarket?The frictions look very poxy.......unfortunately there is no heavy aftermarket ones available Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532714 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 5d Gender: Male Location: Brisbane Posted 15/05/07 06:35 AM Share Posted 15/05/07 06:35 AM Faark that's some serious twisting...no wonder they snap Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532719 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 22d Location: In The Ute Posted 15/05/07 06:54 AM Share Posted 15/05/07 06:54 AM F6BF said: Thanks for the pics mateIs the new input shafts now all heat treated or is someone doing them aftermarket?The frictions look very poxy.......unfortunately there is no heavy aftermarket ones availableZF only sell the heat treated ones now but don’t openly admit the old one was a problem ahhahahah.The discs wear is no big deal and a lot is contributed to the tuner and a undersize transmission filter.Each clutch pack has its own modulation valve so you can play with each one individually to engage at different velocity, pressure and disengagement velocity but at the expense of input and intermediate shafts.I’m hoping these new shafts do the trick and then we can wind the rest up until the next part in the food chain breaks. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532726 Share on other sites More sharing options...
F6BF Member 438 Member For: 19y 4m 18d Location: Sydney Posted 15/05/07 07:13 AM Share Posted 15/05/07 07:13 AM Good to know the heat treated ones can be bought over the counterWith a few mods we might be able to keep them together Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-532735 Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 19y 2m 20d Gender: Male Location: Sydney Posted 16/05/07 02:47 AM Share Posted 16/05/07 02:47 AM I think there is more actual information in this thread than there has been in all the other ZF related threads previously Keep sharing fellas! Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-533088 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m Gender: Male Posted 18/05/07 01:28 PM Share Posted 18/05/07 01:28 PM F6 Tornado did you get repair manuals for the ZF. If so where?. Also who is the supplier for the spare parts? Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/page/2/#findComment-534299 Share on other sites More sharing options...
