CSV_LS1 Member 303 Member For: 21y 1m 16d Gender: Male Posted 15/05/07 03:21 AM Share Posted 15/05/07 03:21 AM Can anyone give me a contact of a shop in melbourne that can rebuild them?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/ Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 9m 13d Location: Rolling on my 20's Posted 15/05/07 03:37 AM Share Posted 15/05/07 03:37 AM Has another let go?Details would be nice if any.Dave from Kewish auot can fix them and beef'em up.Spoke to him his done a few now. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532649 Share on other sites More sharing options...
CSV_LS1 Member 303 Member For: 21y 1m 16d Gender: Male Posted 15/05/07 03:47 AM Author Share Posted 15/05/07 03:47 AM (edited) Yeah it's not a happy auto. Trouble quickly engaging gear most times, it shunts when getting off the throttle quickly and feels like it's slipping when taking off in 1st or 2nd.Do you have his contact details?Thanks Edited 15/05/07 06:56 AM by Adam Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532656 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 30d Gender: Male Location: Zombie Birdhouse Posted 15/05/07 04:15 AM Share Posted 15/05/07 04:15 AM Amberley CrescentDandenong, VIC, 3175 Telephone:03 9793 2220 Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532666 Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 9m 13d Location: Rolling on my 20's Posted 15/05/07 04:39 AM Share Posted 15/05/07 04:39 AM Thanks Jules.You should be a Mod!On another note I'm just glad there's someone that's willing to fix the boxes, which means we can give the boxes more torque and rwkw's to worry about hehe. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532673 Share on other sites More sharing options...
CSV_LS1 Member 303 Member For: 21y 1m 16d Gender: Male Posted 15/05/07 04:52 AM Author Share Posted 15/05/07 04:52 AM Thanks for that.Making them stronger now and not having to make do with rebuilt standard boxes now is whats needed. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532682 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 10d Location: In The Ute Posted 15/05/07 04:55 AM Share Posted 15/05/07 04:55 AM Biggest problem is the filter (which is part of the pan) gets blocked once you up the rwkw’sChange it out regular and that makes heaps difference.The input shafts SNAP and/or twist. The clutch material that blocks the filter is mainly from the direction pack but these discs are cheap as chips to buy genuine.Most of the shift problems are simply caused by low oil flow and pressure due to the filter.They are actually very cheap to overhaul. Having said that there is no benefit in beefing the packs up because that will only cause the input shaft to snap sooner. Although the new genuine input shafts look to have a different heat treatment process than the early ones. So in time it might be worth adding another couple of discs and plates. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532683 Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 9m 13d Location: Rolling on my 20's Posted 15/05/07 05:10 AM Share Posted 15/05/07 05:10 AM Some good info there and I've been told exactly the same thing as you.The only other addition has been there's been a few phoons that have had aftermarket coolers installed (in melbourne) and so far no issues from what I've heard.500rwkw here we come! Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532688 Share on other sites More sharing options...
F6_Tornado F6+300+ Member 940 Member For: 20y 5m 10d Location: In The Ute Posted 15/05/07 05:43 AM Share Posted 15/05/07 05:43 AM The cooler won’t help you one bit apart from keeping the oil cool on low HP vehicles.You don’t need to have hot oil to Snap the input shaft. Just lots of HP. So to me unless you do track work, the original cooler is fine. neither will save your input shaft. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532705 Share on other sites More sharing options...
Billsta Member 355 Member For: 18y 9m 13d Location: Rolling on my 20's Posted 15/05/07 05:50 AM Share Posted 15/05/07 05:50 AM Im quite interested in doing some track work in the near future so the cooler may come in handy.I agree with you on the standard cooler for street use though my car is screaming for some track time.The input shaft is a definate weak point and surely will let me down sooner or later. I'm sure the box will be overhauled once the tough bottom end goes in. Link to comment https://www.fordxr6turbo.com/forum/topic/34989-rebuilding-zfs/#findComment-532706 Share on other sites More sharing options...
