RHR BOOST Moderating Team 5,698 Member For: 21y 7m 18d Gender: Male Location: Southern Highlands NSW Posted 14/05/07 09:57 AM Share Posted 14/05/07 09:57 AM I think that's your clutch saying its not too happy with the xtra power.. My clutch no like me after I did the edit Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532315 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 8m 4d Gender: Male Location: Zombie Birdhouse Posted 14/05/07 09:59 AM Share Posted 14/05/07 09:59 AM tab said: Jetute had the same thing, was from a 5-speed based edit tune rather than a 6-speed Was hilarious at the time watching the poor bastard trying to find the correct tune so he could reverse out of the carpark and you reckon I'm an evil bastard Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532319 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 11m 29d Gender: Male Location: Brisbane Posted 14/05/07 10:05 AM Share Posted 14/05/07 10:05 AM No Buffy, I'm sure you wouldn't have laughed at him Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532324 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 2m 16d Gender: Male Location: The Shire Sydney AUS Posted 14/05/07 10:10 AM Share Posted 14/05/07 10:10 AM (edited) I thinks it might be your reverse lockout solenoid .... possibly 1 setting in the edit, get ure tuner look at it.or it could be a sticky solenoid.....Or try pumping the clutch b4 you put it in R, if that makes it easier, ure clutch might be rooted... Pete Edited 14/05/07 10:11 AM by stealthxr Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532328 Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 21y 2m 22d Gender: Male Location: brisbane Posted 14/05/07 10:13 AM Share Posted 14/05/07 10:13 AM (edited) tab said: Jetute had the same thing, was from a 5-speed based edit tune rather than a 6-speed Was hilarious at the time watching the poor bastard trying to find the correct tune so he could reverse out of the carpark yeah thanks tabitha!!!! am gald some found it funny cause I was farking furious...anyway tabs right on the money.... the tuner has used a 5 speed manual base tune..... and this farks up reverse and does not open the gate and hence you have to force it trhough.The tuner needs to use the 6 speed map base code on the side of the ecu and rewrite a new tune... the problem is that they use the generic tunes sent and try to work of these only.... and all the originals were from the 5 speed.... get them to base it of your ecu code and the problem will dissapear!!!!!!!!!!!!!!!! ps... I wouldnt want to be forcing it through the gate too often..... get it fixed immediately as its an electric gate controlled by the ecu!! Edited 14/05/07 10:22 AM by jetute Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532330 Share on other sites More sharing options...
Max Power Member 381 Member For: 20y 11m 20d Location: MENAI, NSW Posted 14/05/07 12:04 PM Share Posted 14/05/07 12:04 PM Its definitely the T5 program that youve got instead of the T56. Right about now I would be changing tuners if I were you. Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532451 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 11m 29d Gender: Male Location: Brisbane Posted 14/05/07 09:35 PM Share Posted 14/05/07 09:35 PM jetute said: yeah thanks tabitha!!!! am gald some found it funny cause I was farking furious...I never said I was laughing though Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532531 Share on other sites More sharing options...
Paul@eliteauto Member 843 Member For: 18y 7m 23d Gender: Male Location: Brisbane Posted 15/05/07 11:38 AM Share Posted 15/05/07 11:38 AM Who ever did the tune for you has used the wrong strategy.The only way to rectify it is do the tune again using the the right strategy.Normaly get this problem with generic tunes.This is SCT tuning 101.Cheers Paul Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532900 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 10m 3d Location: Canberra Posted 15/05/07 12:01 PM Share Posted 15/05/07 12:01 PM sometimes my T5 is hard to get reverse and 1st (ever since I had the clutch upgraded).. I usually just knock it into 4th or 3rd, and then try again and it's fine. Probably not the same issue though Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-532919 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 10m Gender: Male Posted 16/05/07 12:47 AM Share Posted 16/05/07 12:47 AM im not sure how you do it but mine is wired in so that the gate for reverse only opens when you have your foot on the brake. this is how mal woods recommend you do it, and ninka got mine done in around 10 mins.. may be worth looking into! Link to comment https://www.fordxr6turbo.com/forum/topic/34956-reverse-gear-selection-manual-6-speed/page/2/#findComment-533040 Share on other sites More sharing options...
