  • Member For: 18y 2m 7d
haha this is frustrating when I dont even have my toy yet!! I want bigger IC too, ive gota start plannin now b4 the mrs finds out :welcome2:
  • Member For: 18y 2m 5d
you might want a bigger IC but the question is why??? If for looks the go for it. If for power then standard IC is ok . Check out the kits Nizpro/HPF etc put together. A bigger IC is worth it if you want sustained power, track days eg. Heat soak is the issue with the standard IC.
Bigger IC's are better at maintaining cooler inlet temps so they are better. They do restrict airflow to the radiator which doesn't help block temp. Cost is anywhere from $300 to 1500 for a stage1 upgrade. I'd buy bigger brakes with that $$$
