furioso Member 47 Member For: 18y 2m 9d Gender: Male Location: Perth W.A. Posted 11/05/07 07:20 AM Share Posted 11/05/07 07:20 AM (edited) Performance Package:Flash Tuner 42lb Injectors Slim T-Rex Fuel Pump Twin 2.5" Cat-Back Exhaust, Stainless Cold Air Intake K&N Filter330 - 350kW for around $2900 does this sound correct? just been lookin at some sites, this was on capa btw. I really didnt think it would be that easy to mod these things if this is the case also wats the deal with permits? anyone in w.a had anytrouble with needin permits? Edited 11/05/07 07:21 AM by furioso Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/ Share on other sites More sharing options...
LTS60 They see me rolllin n hatin... Member 427 Member For: 18y 11m 11d Gender: Male Location: Brisbane Posted 11/05/07 07:26 AM Share Posted 11/05/07 07:26 AM You need a new clutch on top of that or transmission cooler if its auto. Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531100 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 10m 11d Gender: Male Posted 11/05/07 07:43 AM Share Posted 11/05/07 07:43 AM capa site doesn't include fitting =) Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531103 Share on other sites More sharing options...
furioso Member 47 Member For: 18y 2m 9d Gender: Male Location: Perth W.A. Posted 11/05/07 07:56 AM Author Share Posted 11/05/07 07:56 AM yeh so like 3500 fitted? yeh my car will be auto Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531107 Share on other sites More sharing options...
INFLYT Donating Members 784 Member For: 18y 9m 22d Gender: Male Location: N.S.W, Sydney Posted 11/05/07 10:01 AM Share Posted 11/05/07 10:01 AM Im assuming those figure's are quoted as being flywheel kilowatt's? Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531194 Share on other sites More sharing options...
furioso Member 47 Member For: 18y 2m 9d Gender: Male Location: Perth W.A. Posted 13/05/07 02:15 AM Author Share Posted 13/05/07 02:15 AM whats flywheel kw? Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531732 Share on other sites More sharing options...
howitzer85 Member 241 Member For: 18y 2m 11d Gender: Male Location: The marsh... Posted 13/05/07 04:38 AM Share Posted 13/05/07 04:38 AM furioso said: whats flywheel kw?The power produced at the engine. The power at the wheels will generally be around 70% of this figure maybe a bit more depending on what gearbox... Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531756 Share on other sites More sharing options...
furioso Member 47 Member For: 18y 2m 9d Gender: Male Location: Perth W.A. Posted 13/05/07 07:50 AM Author Share Posted 13/05/07 07:50 AM hrrrm well that does seem more accrurate. Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531813 Share on other sites More sharing options...
01txr Member 861 Member For: 18y 3m 18d Gender: Male Location: QLD Posted 13/05/07 08:12 AM Share Posted 13/05/07 08:12 AM Yes that would be at the flywheel because if it was at the back wheels you would need things like wastegate mod, and bigger injectors I would think.I have read a bit on the Capa site and think that they usually use flywheel power figure's.With what you have quoted you should be able to get it cheaper than that.Flash Tuner $75042lb Injectors $450 siemens 660cc think they are 60lbSlim T-Rex Fuel Pump $300 (Walbro)Twin 2.5" Cat-Back Exhaust, Stainless $200 max (remove center muffler)Cold Air Intake $60 (typhoon 2nd cai from ford)K&N Filter $80 (redline)Total $1840maxPlus get a full custom tune and fitment for around Capa's price. Give you around 270-290rwkw pending tuner and how far you want to push the tune.Or you could go to the next stepFlash Tuner $75042lb Injectors $450 siemens 660cc think they are 60lbSlim T-Rex Fuel Pump $300 (Walbro)Twin 2.5" Cat-Back Exhaust, Stainless $1700 (full x-force)Cold Air Intake $60 (typhoon 2nd cai from ford)K&N Filter $130Wastegate mod with 12lb actuator Approx $500 if you remove and fit.Anywhere between 300-350rwkw pending tuner and how far you want to push the tune.I would reckon not to push past 320rwkw on standard rods and pistons.So if you decide to go to this level go for a softtune that won't put to much stress on your motor.Keep in mind I have been told that motor is only strong to 320-350rwkw pending who you ask.I can't say this is gosspel as it is only from what I have read on the forums.However my BA XR6T manual had made 270rwkw with:Nizpro valve springsnizpro high flowed injectorsWalbro fuel pumpK&n Filtercapa custom tuned edit by can't recall (already done when I purchased)center muff removed@10 PSI Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531822 Share on other sites More sharing options...
furioso Member 47 Member For: 18y 2m 9d Gender: Male Location: Perth W.A. Posted 13/05/07 10:08 AM Author Share Posted 13/05/07 10:08 AM okay there is sooo much things to read and everyone seems to be slightly different in opinions. I havent got my car yet, but it will be a bf mkII 6speed auto. and on the performance side of things ill be spending around 4500. what kind of power and quality am I lookin at with that? Link to comment https://www.fordxr6turbo.com/forum/topic/34859-performance-package-and-permits/#findComment-531872 Share on other sites More sharing options...
