Jake F6 Donating Members 327 Member For: 21y 7m 5d Location: Melbourne Posted 18/07/03 12:14 AM Share Posted 18/07/03 12:14 AM I just found out that shootout mode gives 10% higher readings than normal mode.So the XR6T Manulas that got 202-210 were really 180-189 (Motor magazine got 185 for a manual.They got 225 for a GT) This also suggests that the 252 GT on the day was a real figure of 226 which again is correct. The two 290 Utes that made 230, obviously need more Km's on them to make the same output.My car made 142 which is a real figure of 128. This multiplied by 1.34 (for manual) gives flywheel 172, which is exactly what Ford quotes for my car.In short, shootout readouts should be multiplied by .9 to compare with cars run in 'normal' mode.Jake. Link to comment Share on other sites More sharing options...
bez Member 92 Member For: 21y 8m 20d Location: Brisbane Posted 18/07/03 12:43 AM Share Posted 18/07/03 12:43 AM boo Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 21y 9m 24d Gender: Male Posted 18/07/03 01:56 AM Author Share Posted 18/07/03 01:56 AM I just found out that shootout mode gives 10% higher readings than normal mode.So the XR6T Manulas that got 202-210 were really 180-189 (Motor magazine got 185 for a manual.They got 225 for a GT) This also suggests that the 252 GT on the day was a real figure of 226 which again is correct. The two 290 Utes that made 230, obviously need more Km's on them to make the same output.My car made 142 which is a real figure of 128. This multiplied by 1.34 (for manual) gives flywheel 172, which is exactly what Ford quotes for my car.In short, shootout readouts should be multiplied by .9 to compare with cars run in 'normal' mode.Jake.not quiet right ... the shootout mode is generally about 5-6% higher than non shootout modes ....but the good thing about it is ... that it is repeatable any day and any time ... and if the machines are properly calibrated ... the same on any dynodynamics dyno ...in no shoot out ... I've had variations of 20rwkw .. due only to the humidity, temperature and barometric pressure ... on the same dyno ...another interesting figure is the rear wheel to fly wheel conversion ... 1.3 to 1.4 is reasonablelastly, and this is 2c worth, most of the published figures in mags etc .. don't say shootout or whatever .... so it can be hard to compare...and shootout is going to be the likely standard as it is a dynodynamic product which is being pushed hard ... Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 21y 9m 24d Gender: Male Posted 19/07/03 02:54 AM Author Share Posted 19/07/03 02:54 AM the final results for the XRTsPeak power/ trans/ ID/ Kms/ service/ fuel/ a/f & boost210.0rwkw manual IMTRBO 2000 - pulp 13-11 6-5209.8rwkw manual gctaylor 13000 15k BP ult 12.5-11.5 6-5 206.3rwkw manual Dagabond 17500 15k opti 13-11 6-5 202.0rwkw auto XRCISM 17000 15k opti 12-11 5.5 200.9rwkw auto GEEA 10100 ecu fix opti 12.5-11.5 6-5 195.0rwkw auto Attessa 1800 opti 12-11 6-4.5 193.1rwkw auto Richdave 13200 3k ulp+ 12-11 5.5 192.3rwkw auto deek 13300 3k BPpre 12-10 5.5 186.8rwkw auto Peter ??? ?? ulp? 12.5-11 5.5 185.1rwkw auto FPRXR6 4400 3k ulp 12-10 5-4.5 184.6rwkw auto bdennis 9800 3k ulp 11.5-9.5 5-4.5 tried to make a table ... but couldn't format it can you see what I see ?? :D B) makes more sense now ... Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 9m 7d Gender: Male Location: At the lights, waiting for you. Posted 19/07/03 03:33 AM Share Posted 19/07/03 03:33 AM Would it involve much to add a column for A/C on or off BLKXRT? Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 21y 9m 24d Gender: Male Posted 19/07/03 03:40 AM Author Share Posted 19/07/03 03:40 AM Would it involve much to add a column for A/C on or off BLKXRT? a/c are turned off .... Mark sometimes remembers to turn them back on again .... :D Link to comment Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 4m 8d Gender: Male Location: Outer east - Melbourne Posted 19/07/03 04:09 AM Share Posted 19/07/03 04:09 AM doc file attached with tabulated form ... :alien: must have been kidnapped or I'm blind B) Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 21y 9m 24d Gender: Male Posted 19/07/03 04:24 AM Author Share Posted 19/07/03 04:24 AM it's gone ... oh well ... maybe I can say it was all in Dave's imagination B) Link to comment Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 22y 3m 17d Location: Adelaide Hills Posted 19/07/03 05:47 AM Share Posted 19/07/03 05:47 AM Seems to be a reasonable spread of boost from a range of standard cars, varying between 4.5-6.5 lbs if l am reading it right. The cars finished pretty consistently in order of their boost too, not suprising.Wonder how that could be so? Link to comment Share on other sites More sharing options...
xa-coupe Member 95 Member For: 22y 3m 23d Gender: Male Posted 19/07/03 06:11 AM Share Posted 19/07/03 06:11 AM interestingly enough it looks like the guys making the least power are using ULP only. It looks like the extra $ spent on premium or the 98 octane stuff id well worth it. Link to comment Share on other sites More sharing options...
