Mods For The E-gas Motor
nods
  • Boostaholics anonymous
  • Member For: 18y 4m 14d
The calorific value of some race fuels is below petrol also, doesnt make anyone who uses them tightarses..
I know of a 9 sec XE ESP 250 xflow on LPG. cant be that bad. Just the available metering systems suck
  • Member For: 18y 10m 17d
An easy way to get it going harder, is to actually use BBQ gas, it has a greater percentage of butane in it than what "pump LPG" has...
Don't know how good it is for the engine but I knows it works..
Pete...
I'll also like to know if a LPG car can use the edit????
Nothing wrong with going the road less taken and at the end of the day you'll know the results before a lot of others who just keep walking the path of the Turbo. Good for you mate work the LPG.
Under Drive may Fit, not sure.
  • Member For: 19y 6m 11d
I get them in at work all the time, they are ok, but its hard to call them anything exciting at all when you own a T. What I was going to suggest to you is you will notice a big difference in putting in 3:45 diff gears out of an XR compared to the factory 3.08s (don't know if the ratio's quoted are 100% spot on). That does make a difference if it hasn't already been done :blink:
Using you theroy then I should never get into another car with lower power than 400 rwkw then as it just wouldent do anything for me?? I tell you though you can certianly have some fun with lower power as you would know.... :spoton:
