Mods For The E-gas Motor
nods
  • Member For: 17y 9m 28d
GGF :msm:
Hey Tony, Actually its not as underpowered as you'd think!
this is the 3rd Ba ive had, I had a 03 model lpg before this
and this has more power ! this one the 05 model
is an ex cop car I dont know what they've done but there
is a diference
  • Member For: 18y 11m 5d
is a diference
I get them in at work all the time, they are ok, but its hard to call them anything exciting at all when you own a T. What I was going to suggest to you is you will notice a big difference in putting in 3:45 diff gears out of an XR compared to the factory 3.08s (don't know if the ratio's quoted are 100% spot on). That does make a difference if it hasn't already been done :msm:
I get them in at work all the time, they are ok, but its hard to call them anything exciting at all when you own a T. What I was going to suggest to you is you will notice a big difference in putting in 3:45 diff gears out of an XR compared to the factory 3.08s (don't know if the ratio's quoted are 100% spot on). That does make a difference if it hasn't already been done :veryangry:
Gooday Tony, Thanks that's a good idea! I'll look
into that and see, if its not done that's a good place to start
I got a feeling thay've done something just not sure what.
Cheers Nods
  • www.australianflag.org.au
  • Member For: 19y 7m 9d
Mate the suprising thing is, from memeory Gas is over 100 RON and therefore should be able to produce good power. There may be a another equation I dont understand. I just wished that gas was not taxed so early and let the development run before it was cost viable. I rekon it would be very much main stream.
Scotty
Scotty
It also takes heat from the inlet to, but that doesn't detract from the caloric value of gas being less than petrol, hence why its good for tightarses and BBQ's :spoton::spoton:
