Filopastry Member 49 Member For: 18y 1m 4d Location: Sydney Posted 08/05/07 01:05 AM Share Posted 08/05/07 01:05 AM Hey guys, was talking to someone about his xr6T on Myspace and he suggested this;"and with the Factory BOV ( blow of valve ) located at the back near the firewall the BOV will be sitting there all u need to do is dissconet it block of the 25mm oulets from the hoses and this make the loudess dose"Didn't really sound like a smart thing to do when I first read it... Any thoughts?? Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/ Share on other sites More sharing options...
Harry_BFXR6T Member 17 Member For: 18y 2d Posted 08/05/07 01:23 AM Share Posted 08/05/07 01:23 AM Yeah that'll workThe BOV is releaseing air, befor it gets the chance to come out of the mouth of the turbo. Thus without the BOV, more air for Dosing, creating a louder Dose.Removing the BOV shouldnt damage your car, its only disigned to keep your Turbo Spoolling by releasing back pressure. Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-529831 Share on other sites More sharing options...
Filopastry Member 49 Member For: 18y 1m 4d Location: Sydney Posted 08/05/07 01:25 AM Author Share Posted 08/05/07 01:25 AM Oh ok. Has anyone done this already and possible taken photos ha? Ill look through the workshop section but if anyone has some instructions on how to do this it would be great!! Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-529832 Share on other sites More sharing options...
YellowTurbo Member 163 Member For: 18y 7m 12d Gender: Male Location: Darwin Posted 13/05/07 10:08 AM Share Posted 13/05/07 10:08 AM It's not really a good thing to do, cause all the pressure to come out the front of the turbo.You could try making the stock Bov to atmosphere but the standard valves tend to leak, causing poor idealingdale Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-531871 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 18y 11m 28d Gender: Male Posted 13/05/07 10:13 AM Share Posted 13/05/07 10:13 AM It will be fine I have run mine like this for over a year on 11psi no dramas Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-531879 Share on other sites More sharing options...
XRDOSE BIGRED Donating Members 1,410 Member For: 18y 1m 9d Gender: Male Location: Sth East Melb Posted 14/05/07 11:19 AM Share Posted 14/05/07 11:19 AM I had my blow off valve taken out and the hoses plugged for a while it sounded awesome! then I did the stupidest thing last nite and put the blow off valve back in! sounds pretty sh*te! so it'll b comin out next weekend! then I can dose it up again! but ye that's all u gotta do take the blow off valve out block the hoses as well as the vacuum hose then its dosing central! Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-532414 Share on other sites More sharing options...
jcooke Member 272 Member For: 18y 7m 2d Gender: Male Location: Brisbane, QLD Posted 14/05/07 11:46 AM Share Posted 14/05/07 11:46 AM dosing? what is this dosing u speak of? audio pleaseeee Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-532436 Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 19y 1m 8d Gender: Male Location: nsw Posted 14/05/07 09:52 PM Share Posted 14/05/07 09:52 PM I have heard that if you use protection you wont get a dose. Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-532534 Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 3m 26d Gender: Male Location: Not sure? Posted 14/05/07 10:39 PM Share Posted 14/05/07 10:39 PM jcooke said: dosing? what is this dosing u speak of? audio pleaseeeeIt sounds like you have a couple of Turkey's mating under the bonnet. BFHOON said: I have heard that if you use protection you wont get a dose. Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-532539 Share on other sites More sharing options...
mpsxr6t Member 112 Member For: 18y 4m 9d Gender: Male Location: Melbourne Posted 15/05/07 03:02 AM Share Posted 15/05/07 03:02 AM so u would put chair leg tips over the hole near the the throttle body and over the hole at the bak of the intake where it is plumbed bak 2? and how do u block the vacuum line?is that the little 1 that goes to the top of the bov?wat do u block that with....is this safe? does is cause 2 much pressure on the turbo? or engine? answers 2 this would b good Link to comment https://www.fordxr6turbo.com/forum/topic/34773-disconnecting-the-factory-bov-and-blocking-the-hole/#findComment-532638 Share on other sites More sharing options...
