jyoung71 Inactive Members 1 Member For: 18y 2m 5d Posted 07/05/07 10:50 AM Share Posted 07/05/07 10:50 AM Hi Everyone,Does anyone know if there is a provision to install an electric brake controller in a for territory. The car is fitted with the Ford Heavy Duty towpack, and inside the 12 pin trailer plug there is wiring for the trailer brakes connected. I am assuming that this goes up to the dash somewhere so you can install the contoller somewhere.Just asking before I start putting in extra cabling and splicing into power and brake wiring to get it all to go.Any help would be appreciated.RegardsRacin Jason Link to comment Share on other sites More sharing options...
cqae Member 229 Member For: 21y 2m 12d Posted 07/05/07 11:52 AM Share Posted 07/05/07 11:52 AM yeah you can fit one almsot anywhere on them. there will be spare wires, you will be running a 14 pin plug-2 rows of 7 pins. both rows will have 2 spare wires on them that dont do anything but will have wires in them running back up the loom. the blue wire-I think its pin 6 or 7. this is the service brake pin, you should run wire from the unit all the way to the plug as the wire in most 5 or 7 core is not adequate.as far as units go, I mostly sell tekonsha or redarc, I would recomend redarc cos they are smaller & easier to mount, where as the tekonsha one, the prodigy series is the worlds largest selling unit, they both work well. but the tekonsha one has to be mounted horizontally & with 0-90degree angle, which can be sometimes a little hard. the redard does not look as good but can be mounted in any location or position. Link to comment Share on other sites More sharing options...
