outdoor34 Member 15 Member For: 18y 2m 3d Gender: Male Location: Rockingham W.A Posted 05/05/07 09:25 AM Share Posted 05/05/07 09:25 AM HiHave a slight knocking sound from the rear of the car when I hit a few slight bumps,,, me thinks suspension any ideas Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/ Share on other sites More sharing options...
Goobz Member 746 Member For: 20y 7m 9d Location: Sutherland Shire, Sydney Posted 05/05/07 02:12 PM Share Posted 05/05/07 02:12 PM Yeah I developed this after ford replaced my diff. Kind of a metal on metal sound.Mine also does it if I go into a driveway at an angle to(ie. one wheel tucked up and one wheel hangs down)Its already been in once to be fixed but as usual they did nothing...Keep me posted if you work out what it is.Anybody got any ideas?Chris Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529053 Share on other sites More sharing options...
Goobz Member 746 Member For: 20y 7m 9d Location: Sutherland Shire, Sydney Posted 06/05/07 10:24 PM Share Posted 06/05/07 10:24 PM Has anyone got any ideas what it might be?I want to find out for myself before I take it back to them, so I can just say FIX THIS!!!They are obviously incapable of finding it...ThanksChris Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529343 Share on other sites More sharing options...
stealthxr Donating Members 553 Member For: 19y 3m 14d Gender: Male Location: The Shire Sydney AUS Posted 06/05/07 11:38 PM Share Posted 06/05/07 11:38 PM Diif Bush Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529356 Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 4m 15d Gender: Male Location: Not sure? Posted 06/05/07 11:44 PM Share Posted 06/05/07 11:44 PM stealthxr said: Diif BushTook the words out of my mouth Pete. But then it could also be the entire rear subframe. Mine had a noise 2 years ago, that was like a bowling ball rolling around in the boot when I turned under power or went up driveways. The rear section was totally loose. Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529358 Share on other sites More sharing options...
MUZ580 Member 448 Member For: 19y 1m 22d Gender: Male Location: Manly - Sydney Posted 07/05/07 12:27 AM Share Posted 07/05/07 12:27 AM I've got the same problem, accelerating around a courner and it rattles, sounds a bit like a CV in a front wheel drive car just before it breaks. Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529378 Share on other sites More sharing options...
outdoor34 Member 15 Member For: 18y 2m 3d Gender: Male Location: Rockingham W.A Posted 07/05/07 11:16 AM Author Share Posted 07/05/07 11:16 AM I do not believe that mine is a diff problem,,, as it only seems to happen on over slightly bummy roads,,, I have read on a previous thread that shockies stuffed or may be loose sway bar,,, or another thought was some bolt that bumps the fuel tank I think they said something about diff cradle... one more idea was a loose fuel tank Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529641 Share on other sites More sharing options...
galconn Member 101 Member For: 19y 8m 29d Posted 07/05/07 11:25 AM Share Posted 07/05/07 11:25 AM outdoor34 said: I do not believe that mine is a diff problem,,, as it only seems to happen on over slightly bummy roads,,, I have read on a previous thread that shockies stuffed or may be loose sway bar,,, or another thought was some bolt that bumps the fuel tank I think they said something about diff cradle... one more idea was a loose fuel tankHad very similar syptoms. Make sure the rear sway bar linkages are in good condition. I had mine replaced within 12 months of new, and even though they looked ok it was not until they were removed and inspected that the problem was evident - bushes were *&^%$#. New ones fitted under warranty. Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529647 Share on other sites More sharing options...
Bain Member 827 Member For: 20y 2m 22d Gender: Male Location: Melbourne Posted 07/05/07 11:23 PM Share Posted 07/05/07 11:23 PM Check to make sure your exhaust is fitted correctly.It may be hitting on the cross member where the diff is.. Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529801 Share on other sites More sharing options...
2fardown Member 526 Member For: 20y 9d Gender: Male Location: Brisbane Posted 08/05/07 12:11 AM Share Posted 08/05/07 12:11 AM I'm having the same issue. It started happening after I towed a bit of a load. It only happens on a sharp bump, a slight knock from the rear end.I suspect it's my exhaust as it hangs quite low in the back. Link to comment https://www.fordxr6turbo.com/forum/topic/34714-rear-thumping-noise-in-suspension/#findComment-529807 Share on other sites More sharing options...
