  • Member For: 20y 7m 14d
Yeah I developed this after ford replaced my diff. :gooff:
Kind of a metal on metal sound.
Mine also does it if I go into a driveway at an angle to(ie. one wheel tucked up and one wheel hangs down)
Its already been in once to be fixed but as usual they did nothing...
Keep me posted if you work out what it is.
Anybody got any ideas?
Chris :laughing:
Has anyone got any ideas what it might be?
I want to find out for myself before I take it back to them, so I can just say FIX THIS!!!
They are obviously incapable of finding it...
Thanks
Chris
  • CNUTOX
  • Member For: 22y 4m 19d
  stealthxr said:
Diif Bush
Took the words out of my mouth Pete.
But then it could also be the entire rear subframe. Mine had a noise 2 years ago, that was like a bowling ball rolling around in the boot when I turned under power or went up driveways. The rear section was totally loose.
  • Member For: 19y 1m 26d
I've got the same problem, accelerating around a courner and it rattles, sounds a bit like a CV in a front wheel drive car just before it breaks.
  • Member For: 18y 2m 7d
I do not believe that mine is a diff problem,,, as it only seems to happen on over slightly bummy roads,,, I have read on a previous thread that shockies stuffed or may be loose sway bar,,, or another thought was some bolt that bumps the fuel tank I think they said something about diff cradle... one more idea was a loose fuel tank
  • Member For: 19y 9m 3d
Had very similar syptoms. Make sure the rear sway bar linkages are in good condition. I had mine replaced within 12 months of new, and even though they looked ok it was not until they were removed and inspected that the problem was evident - bushes were *&^%$#. New ones fitted under warranty.
  • Member For: 20y 13d
I'm having the same issue. It started happening after I towed a bit of a load. It only happens on a sharp bump, a slight knock from the rear end.
I suspect it's my exhaust as it hangs quite low in the back.
