  • Bored Member
  • Administrator
  • Member For: 22y 6m 2d
  Quote
THIS SCANNER ALLOWS YOU TO SEE WHERE & WHAT THE PROBLEM IS AND TURN OFF THE LIGHT.
Oh that's a big selling point....
  • Member For: 20y 7m 1d
I have one of those Jaycar ones it is an autel GS300. I havent been game to plug it into the car yet, to scared it will bugger something up. it says it is a CAN ODBII scan tool
MG
  • Member For: 21y 27d
MG
Yep, its fine to use. The one in the ebay link in the first post is an Autel GS400. The difference between the two, is that the GS400 has a comprehensive LCD readout telling you what its doing, and what its found (or not found), whereas with the GS300 you have to look codes up in a booklet, or on the CD. Both support CAN.
Here's the GS300 for $100 from the same dude:
Autel GS300 from the same dude
I've used a GS400 on my car, my brothers BF GT, and the folks BFII Fairmont Ghia. It connected to, and read the computers in all three no probs. As stated however, I highly doubt it can read the FoMoCo specific codes. Most likely only reads the generic OBDII P codes. Even so, a tool that only reads the 'generic' codes is better than nothing.
Edited by Spruce
  • Member For: 18y 21d
  wasxaman said:
I can't find it in the Jaycar catalogue.
What is the catelogue number?
Jaycar ....... QP-2294
Re, As stated however, I highly doubt it can read the FoMoCo specific codes. Most likely only reads the generic OBDII P codes.
I keep one of the units in my car just in case. - Genis CAN GS 300 -
It will " Support multiple trouble codes requests: generic codes, pending codes and manufacturer's specific codes."
There are a number of OBD2 Code sites on the Internet to get all the information re Codes.
I also got a unit that will read " some " live data.
Hope this helps.
  • Tractor Driver
  • Member For: 19y 3m 6d
Hope this helps.
What are the site addresses? What is the make/model of the scan tool, and what data does it read?
