cv8z Member 125 Member For: 18y 7m 9d Location: Brisvagas Posted 27/04/07 01:15 PM Share Posted 27/04/07 01:15 PM Hi GuysI bought a walbro gss341 fuel pump off ebay,I had a performance tuner install the pump for me today,He made note that the inlet pipe (under the fuel strainer/filter) was the same size as the stock xr6t fuel pumps.His Walbro fuel pumps he sells have a much larger inlet feed.The fuel pump I bought does have "Walbro" stamped on the side.Any ideas guys if I got ebay scammed ???Cheers Link to comment Share on other sites More sharing options...
MUZ580 Member 448 Member For: 18y 9m 30d Gender: Male Location: Manly - Sydney Posted 27/04/07 09:09 PM Share Posted 27/04/07 09:09 PM Which seller did you guy it from and how much did you pay? Link to comment Share on other sites More sharing options...
cole trickle Donating Members 237 Member For: 19y 21d Gender: Male Location: Melbourne, Vic Posted 28/04/07 10:10 AM Share Posted 28/04/07 10:10 AM As above, which seller was it?CHeers Dalesy Link to comment Share on other sites More sharing options...
gu4800 Member 156 Member For: 17y 9m 17d Location: Brisbane Posted 28/04/07 11:43 AM Share Posted 28/04/07 11:43 AM Anyone bought from this seller:http://cgi.ebay.com.au/GENUINE-600HP-GSS34...1QQcmdZViewItemIf so, genuine?ThanksDan Link to comment Share on other sites More sharing options...
cv8z Member 125 Member For: 18y 7m 9d Location: Brisvagas Posted 28/04/07 12:25 PM Author Share Posted 28/04/07 12:25 PM Sorry for the late reply.Been playing with Vista (not bad at all no problems so far)I bought it from this bloke,http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...p;rd=1&rd=1 Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 9m 29d Gender: Male Posted 28/04/07 01:05 PM Share Posted 28/04/07 01:05 PM you just got the wrong pump. its the 294 with the larger pickup and higher flowing Link to comment Share on other sites More sharing options...
cole trickle Donating Members 237 Member For: 19y 21d Gender: Male Location: Melbourne, Vic Posted 28/04/07 01:25 PM Share Posted 28/04/07 01:25 PM I got my pump from the same people, even had them install it, no complains here, Cheers Dalesy Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 5m 17d Gender: Male Location: Melb Posted 28/04/07 02:50 PM Share Posted 28/04/07 02:50 PM the GSS341/342 walbro pumps have the same size inlet feed as the standard pumps, they are rated at 255l/h at 3barThe pump he is getting confused with is the walbro GSS294, which has the big fat inlet feed, this one is rated at 5bar (180l/h approx). but never the less, this is the pump you want as we run 4bar fuel presure base, then with every 15psi boost, go up 1 bar. so 5 bar. Exactly what the pumps rated at. Link to comment Share on other sites More sharing options...
cv8z Member 125 Member For: 18y 7m 9d Location: Brisvagas Posted 29/04/07 02:56 AM Author Share Posted 29/04/07 02:56 AM So the answer is I got the correct fuel pump ?Will this pump handle my mods1/ edit (Thanks to Paul from "Elite Automotive"2/ Siemems Deka Injectors3/ 2nd CAI4/ Rear Muffler removedDo I realy need valve springs (I have a 2004 BA xr6t) Cheers Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 5m 17d Gender: Male Location: Melb Posted 29/04/07 03:05 AM Share Posted 29/04/07 03:05 AM So the answer is I got the correct fuel pump ?Will this pump handle my mods1/ edit (Thanks to Paul from "Elite Automotive"2/ Siemems Deka Injectors3/ 2nd CAI4/ Rear Muffler removedDo I realy need valve springs (I have a 2004 BA xr6t) CheersPeople have used the GSS341, GSS342 and GSS294 with no problems. It will handle all those mods you have done.And yes, You need valve springs, you will find your valves float when you start pushing more power / boost.d. Link to comment Share on other sites More sharing options...
