  • Member For: 19y 4m 13d
I have just ordered racing hart cr's (same as brian's) in 19x10 and I had to get +28 offset with some massaging they should fit, I hope. But this is on a sedan. talking to some guys where I am getting my tyres they said they just put 305's on a ute with 10" rim and they fit fine. just go do some measurements. see how much room you have from the inside of your standard rim to the struts and how much room you have from the outside lip to the guard and then use this site, http://www.1010tires.com/WheelOffsetCalculator.asp to calculate and it will give you how much room you will have left on each side. have a play around and find what offset fits. but saying that some wheels are only available in some offsets. you will need to roll the guards but other than that you should be fine
https://www.fordxr6turbo.com/forum/topic/34536-what-offest/#findComment-526670
  • Member For: 19y 10m 17d
+28 with a 10inch.... I would have thought you would be pushing your luck with that offset. I know a +30 and 20 x 8.5 inch wide would require lip rolling. I have 20 x 8.5 with a +35 offset and they just fit under the rear (sedan) without the need for rolling the lip. +36 is std I think.
https://www.fordxr6turbo.com/forum/topic/34536-what-offest/#findComment-526952
  • 6 months later...
  • The Cleaning Dudes Ute
  • Member For: 19y 1m 13d
  thommo2007 said:
any luck with finding the right rim offsets ?
as I wanna hav 10inch rears and 9inch fronts on my bf ute also
ditto...
https://www.fordxr6turbo.com/forum/topic/34536-what-offest/#findComment-591340
