Help Help Help
bondy
  • Member For: 17y 7m 27d
HEY GUYS CAN ANY ONE HELP ME ,IVE GOT A BF T ,ITS MAKEING A LOUD WHISTLING SOUND ,AROUND 3500,4000 RPM ,IT ONLY DOES IT WITH THE 10 POUND TUNE IT ,AS SOON AS YOU GET TO THAT RPM IT STARTS ,I PUT THE STANDED TUNE BACK IN IT ,BUT YOU CAN HARDLY HERE IT ,HAS ANY ONE HAD THIS BEFORE .OR HEARD OF IT ,ANY IDEARS WOULD BE GREAT ,IVE CHECKED ALL HOSE TO AND FROM THE COOLER AND TURBO .
  • Member For: 20y 2m 1d
If its only doing it with the 10psi tune I'd say its the turbo. Remember you are allowing it to spool up more, so it will be louder.
Perfectly normal , I wouldn't stress.
Chris :stirthepot:
THANKS CHRIS ,BUT IVE HAD THE 10 PSI TUNE IN IT BE FOR AND IT NEVER USED TO MAKE THAT SOUND .SO I JUST THOUGHT SOME ELES MIGHT OF HAD THE SAME PROBLEM
  • Hench, but no longer shredded or tanned.
  • Member For: 17y 8m 15d
MAYBE YOU NEVER NOTICED IT BEFORE, FROM YOUR FIRST POST ITS ONLY WITH THE 10PSI BOOST, SO IF I WERE YOU I WOULDNT WORRY ABOUT IT
  • Moar Powar Babeh
  • Member For: 19y 2m 20d
TURN OFF CAPS LOCK.!!!! check the cheap ass ford hose clamps the've probably begun to leak under boost
  • Mushroom
  • Member For: 20y 6m 28d
Check all the hoses and clamps again. Sounds like it would probably be a boost leak - as hiddeous has said.
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 18y 7m 9d
or worst comes to worst, turbo compresser blade mine was making a real high pitch squiel under boost I thought it was clamps but it ended up being the compresser wheel, some thing had chiped the blade hence causing that whistling sound.
