quigebo Member 134 Member For: 18y 8m 1d Location: blue planet Posted 22/04/07 03:56 PM Share Posted 22/04/07 03:56 PM when starting, at idle and when in gear at idle ive got a miss..checked the spark plugs and the leads and nothing obvious.. it doesnt stop or surge around it just has what feels like a miss..doesnt break down under load or revs, just at idle.. being an auto at idle when in D it surges around a bit and you can 'feel' the miss..could it be the throttle body or TPS sensor ive read so much about?any ideas would be great Link to comment Share on other sites More sharing options...
Wright'y Member 226 Member For: 20y 10m 5d Gender: Male Location: Darwin, NT Posted 23/04/07 10:14 AM Share Posted 23/04/07 10:14 AM Im pretty sure its all in the tuning, mine was hunting/missing a bit when I brought my car. I got it touched up by a tuner and its been fine since. I would ask your tuner and see what he thinks. If its a constant miss every stroke it could be mechanical but if its missing all over the joint, eg some strokes and not the next, its sounds like its the tuning of the car.hope this helps mateby the way these cars have coil over plugs, not leads. lol Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 29d Gender: Male Location: Perth Posted 23/04/07 10:20 AM Share Posted 23/04/07 10:20 AM Dave its probably the small plug gap that we have to run with high boost levels. Failing that clean out you throttle body. Failing that change the O2 sensor. Mine was knackered and was making the car pop and fart at idle and surge at low rpm like you describe.$55 but off ebay and she was sorted, Tho i think it would be plugs on your car cause your k's are quite low arent they? Link to comment Share on other sites More sharing options...
MICKAJ Member 245 Member For: 16y 10m 26d Posted 06/03/08 08:51 AM Share Posted 06/03/08 08:51 AM HIJACKWhat is actually involved in throttle clean out?? Mine misses on idle aswell, sounds like my old Skyline T. What should plugs be at normally? what is considered a small gap? Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 8m 24d Gender: Male Location: central coast Posted 06/03/08 09:02 AM Share Posted 06/03/08 09:02 AM (edited) there is somethng on it here some where ,can't find it thoughbasically the easy way remove crossover and gently push open throttle body butterfly and soak a rag in carby cleaner then wipe out the inside of the bodystock plugs 1.1mm boosted cars run .75 to .85mm Edited 06/03/08 09:03 AM by our06t Link to comment Share on other sites More sharing options...
Meggs_83 Member 114 Member For: 17y 9m 20d Gender: Male Location: Esperance Posted 06/03/08 09:16 AM Share Posted 06/03/08 09:16 AM I thought it was just a ford thing?? Link to comment Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 17y 11m 7d Gender: Male Location: SYDNEY Posted 06/03/08 09:56 AM Share Posted 06/03/08 09:56 AM I have the same thing and have had it for 1 year now. I have change tps, 3 coils, spark plugs, O2 sensor, regapped plugs and I still have the same problem.. but the car goes gret it only on idle the problem it misses and then I has a big miss and the car actually rocks, you can see and fell the rock.... Link to comment Share on other sites More sharing options...
