CCofOZ Member 40 Member For: 21y 10m 6d Location: Canberra Posted 29/05/03 09:24 AM Author Share Posted 29/05/03 09:24 AM AMoffat> The tyres are assymetrical NOT directional so the spare can go either side.However, as with all radial ply tyres the tyres which start life on the right side should always stay on the right side and similarly for the left tyres ie you rotate tyres front to back on the SAME side of the vehicle.As the spare is rarely used it can be placed on either side and either left on that side or removed to the boot after the original tyre is repaired/replaced and put back to the original position. Exactly what I wanted to hear (tore my hair out all night last night;not that Ive got much left)Cheers more info here than at a ford dealership. Link to comment Share on other sites More sharing options...
Cam Member 397 Member For: 22y 1m 3d Location: Brisbane Posted 29/05/03 11:26 AM Share Posted 29/05/03 11:26 AM AMoffat> The tyres are assymetrical NOT directional so the spare can go either side.However, as with all radial ply tyres the tyres which start life on the right side should always stay on the right side and similarly for the left tyres ie you rotate tyres front to back on the SAME side of the vehicle.As the spare is rarely used it can be placed on either side and either left on that side or removed to the boot after the original tyre is repaired/replaced and put back to the original position. With my previous car I was told NOT to rotate the tyres at all.So basically the tyres that were on the car when I bought it stayed in the same spot untill they wore out - then 4 new ones.And the thing that surprised me was they all wore evenly and at the same rate. I never had the wheels balanced and the car was only serviced once in the tyres 50000Kms life (which was correct for the car - 25000kms service intervals). Link to comment Share on other sites More sharing options...
Guest Mr Walker Guests Posted 30/05/03 02:48 AM Share Posted 30/05/03 02:48 AM Are the 17's different to the 18's as I thought the 18's were directional? Link to comment Share on other sites More sharing options...
Cam Member 397 Member For: 22y 1m 3d Location: Brisbane Posted 30/05/03 07:15 AM Share Posted 30/05/03 07:15 AM I have the 18's and they are directional. Link to comment Share on other sites More sharing options...
BlueXR6Turbo The Best Member Donating Members 1,970 Member For: 22y 1m 24d Gender: Male Location: Adelaide Posted 31/05/03 08:01 PM Share Posted 31/05/03 08:01 PM I have the 18's and they are definitely directional. I thought the 17's were too. Can somebody post a pic showing the tread pattern? Link to comment Share on other sites More sharing options...
sport Member 62 Member For: 21y 10m 13d Posted 31/05/03 11:39 PM Share Posted 31/05/03 11:39 PM Turbo6man is right,the tyres are assymetrical and can run either side of the car as long as correct side is fitted out. having owned a tyre service for 15 years and driven on both dunlop 3000e (current turbo) and dunlop 9000 (last auIII xr8 and heaps of other cars) I can tell you that the dunlop 9000 as used in 18" will "tram track" a lot more than the 3000 and doesn't squeel anywhere as much as the 3000 and also something that not many people realise is that not all 235/45x17 tyres are the same width. Sure they are a noninal 235 wide, but the 3000 is about a good centimetre wider than the 9000 in the same specified width (so less rim damage from gutters) Link to comment Share on other sites More sharing options...
