Xr6t End Of Warranty Nrma Inspection - Great
TURBOTAXI
  • Member For: 22y 4m 2d
Had a RACV inspection done just before the warranty ran out and highly recommend it.
Was a bit worried when they told me that "1 in 5 of these things seem to be full of problems" but happy when all was OK other than a weeping power steering hose. Money well spent I'd say.
  • Member For: 17y 11m 20d
Guys, I have just put a deposit on a XR6T that is almost out of warranty and am about to book it in with the RACV for one of their Pre Warrnaty Expiry Inspection.
Hope it doesn't need anything fixed but if it does need stuff it is good to know I can still get them fixed under warranty.
Will let you know how I get on.
Cheers
James
Yeah I suppose you could. It costs $25 to become a RACV Member but you save more than that if you get the Warranty Inspection.
If nothing needs doing you blow $169 + any extra time whatever that is but if something major needs doing then it is well worth it.
Just like insurance itself its expensive if you dont ever use it but cheap if you do.
Check here for details.
http://www.racv.com.au/wps/wcm/connect/Int...le+inspections/
Well I got the Warranty Check done yesterday and the report last night.
The price blew out to $220 for members as it is a turbo so they have more things to check.
Here The list of what was on the list.
First is the Severity/Nees Done - Second is the Part/Item - Third is the Fault/Comment -
Warranty - Heater Hose On Drivers Side Rear - Coolant Staining Evident/Check Connections
Warranty - Transmission Noise - Whine Audible
Observation - Paintwork and Panels - Minor Chips Evident
Acceptable - Disc Rotor Front/Rear - Slight Pulsation Evident
Observe - RH Front Tyre - Noise Audible (Consistent With Various Brands)
Early Attention Required - Windscreen Washers - Aimed Too Low.
SO to summerise there aint nothing wrong with the car.
I have organised to pick it up tomorrow night.
Was it worth the $220??? Yes as I know nothing is wrong with the car now.
  • Member For: 18y 7m 21d
Even if nothing show's up at all during the inspection, it's piece of mind knowing that the car isn't going to blow up on you, so the inspection is alway's worth the money either way. ;)
  • 2 weeks later...
