youngy Member 293 Member For: 19y 8m 24d Posted 11/04/07 08:26 AM Share Posted 11/04/07 08:26 AM Fat-Tony said: When you start talking 500-600rwkw level of power consider the fact that the engine requires the use of custom plenum at this stage, different camshafts and turbo. By doing all this you are sacrificing a huge amount of bottom end torque, so when you do actually rev dump in 2nd and your engine bogs down lower in the rpm range would you not be caught out by the apparent lack of bottom end torque and have the engine bog down even further.He was talking about slipping the clutch as long as necessary which is easy to do when the wheels are spinning but very difficult when the tyres hook up let alone brutal on the clutch itself especially considering the torque these babies pump out Link to comment https://www.fordxr6turbo.com/forum/topic/34030-manual-launching/page/3/#findComment-520187 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 2m 6d Posted 11/04/07 08:29 AM Share Posted 11/04/07 08:29 AM (edited) youngy said: He was talking about slipping the clutch as long as necessary which is easy to do when the wheels are spinning but very difficult when the tyres hook up let alone brutal on the clutch itself especially considering the torque these babies pump outHehe, I would hate to see the condition of the flywheel and facings after a flare at the strip The real question is, who is game to try it with stock CV's Edited 11/04/07 08:36 AM by Fat-Tony Link to comment https://www.fordxr6turbo.com/forum/topic/34030-manual-launching/page/3/#findComment-520189 Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 11m 8d Gender: Male Posted 11/04/07 09:54 AM Share Posted 11/04/07 09:54 AM 2ND GEAR LAUNCH @ THE DRAGS NO GO.On the street I found it to be good,I done a 0 to 100 in 4.4 with 315 rwkw.I wouldnt do to many of thoes,KISS THE CLUTCH BY BY .CHEERS BB Link to comment https://www.fordxr6turbo.com/forum/topic/34030-manual-launching/page/3/#findComment-520224 Share on other sites More sharing options...
