sinnkexr6t Member 291 Member For: 18y 11m 8d Gender: Male Location: Melbourne, Hampton Park Posted 09/04/07 03:05 AM Share Posted 09/04/07 03:05 AM that looks nasty... Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519278 Share on other sites More sharing options...
Miss_Aly Donating Members 615 Member For: 21y 25d Gender: Female Posted 09/04/07 03:13 AM Author Share Posted 09/04/07 03:13 AM hiddeous said: Some thing quite hard had gone through that. Do you have the standard ford crossover? I've seen the black paint flake off them a couple of times and do similar damage. A new comp wheel and housing shouldn't cost much more than about $250. Might as well do bearing and get it all balanced at the same time. Your probably up for around a grand all up. You'll need to remove the entire intake system and clean it all out. Don't forget to do the pipe work between the filter and the turbo. Alot of debris gets thrown back up there and its often over looked when the system is cleaned and can cause the same damage all over again. Make sure you haven't got any holes in you air filter. Also check your air box for sand. When I had the factory ford airbox it would fill up with and amazing amount of sand and dead bugs..... Thanks for the much needed advice Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519280 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 1m 3d Gender: Male Posted 09/04/07 04:07 AM Share Posted 09/04/07 04:07 AM same thing happend to me, it cost me $200 for the comp wheel and my uncle fixed it for me, as long as the shaft/core hasnt been damaged you should get out of it pretty cheap Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519291 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 2m 25d Gender: Male Location: syd south Posted 09/04/07 04:16 AM Share Posted 09/04/07 04:16 AM there is one on ebay.http://cgi.ebay.com.au/Garrett-GT35-40-BA-...1QQcmdZViewItem Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519296 Share on other sites More sharing options...
Locomick AK47's for everybody Donating Members 131 Member For: 19y 2m 30d Gender: Male Location: somewere Posted 09/04/07 04:24 AM Share Posted 09/04/07 04:24 AM same thing hapend to my turbo . cost me about 1600 for a exchange unit. I carnt remember who I got it off but it came form meld eny way.I know what the cause is. its the house porly made piece of castalloy crossover on top of the engine .when I was looking for what shaged my turbo I looked in the crossover and found a piece of the black heat paint had flaked off ( big as a 50cent piece ) and the top of a bubble in the casting had cracked off. I had it bead blasted before puting it back on. id advise every one to get this done NOW thay are a ticking timebomb.so the moral of the story is its cheaper to replace some turbos under warranty than it is to have a recall and if u are out of warranty ford dont give a rats so id like to give a big thank you to the bean counter at ford and hope u f ing sleep well at night.mick Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519297 Share on other sites More sharing options...
justcrusin Inactive Members 1 Member For: 18y 7m 17d Gender: Male Location: Cootamundra Nsw Posted 09/04/07 04:54 AM Share Posted 09/04/07 04:54 AM that's not good just looked at my turbo it has only done 42k and I found that the pipe had come off due to it being split a little piece of the nut gone also thanx for the info time for a check up Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519304 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 15d Gender: Male Location: Perth Posted 09/04/07 05:05 AM Share Posted 09/04/07 05:05 AM The piece of nut thats missing is probably where it has been machined to balance the rotating assembly and is nothing to worry about... Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519308 Share on other sites More sharing options...
Miss_Aly Donating Members 615 Member For: 21y 25d Gender: Female Posted 09/04/07 06:27 AM Author Share Posted 09/04/07 06:27 AM hiddeous said: I've seen the black paint flake off them a couple of times and do similar damage.we think this may have caused the problem Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519322 Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 22y 4m 9d Gender: Male Location: Melbourne Posted 09/04/07 08:09 AM Share Posted 09/04/07 08:09 AM Yeah mine went too at 70,000 but I just upgraded to an external gate at the time. Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519363 Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 4m 18d Location: Melbourne Posted 09/04/07 09:25 AM Share Posted 09/04/07 09:25 AM loco-no said: same thing hapend to my turbo . cost me about 1600 for a exchange unit. I carnt remember who I got know what the cause is. its the house porly made it off but it came form meld eny way.ipiece of castalloy crossover on top of the engine .when I was looking for what shaged my turbo I looked in the crossover and found a piece of the black heat paint had flaked off ( big as a 50cent piece ) and the top of a bubble in the casting had cracked off. I had it bead blasted before puting it back on. id advise every one to get this done NOW thay are a ticking timebomb.so the moral of the story is its cheaper to replace some turbos under warranty than it is to have a recall and if u are out of warranty ford dont give a rats so id like to give a big thank you to the bean counter at ford and hope u f ing sleep well at night.mickHow does one go about getting it bead blasted, I suppose you can just polish the outside as well.What sort of cost is involved?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/34011-turbo-blades-failure/page/2/#findComment-519399 Share on other sites More sharing options...
