ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 9m 14d Gender: Male Location: Sydney Posted 28/03/09 11:05 AM Share Posted 28/03/09 11:05 AM Take it back to a dealer to get fixed. The car is still under warranty, so make it there problem.The Diffhousing problem is not uncommon in cars that are driven hard. Link to comment Share on other sites More sharing options...
Kermit Member 3 Member For: 15y 8m Posted 28/03/09 11:43 PM Share Posted 28/03/09 11:43 PM Thanks Zap, I'll get it booked in asap. Anyone know if I can still be driving it with the Malfunction Indicator Lamp lit up? I've only had it 5 days and I'd love to be gettin' out in it. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 9m 14d Gender: Male Location: Sydney Posted 29/03/09 12:52 AM Share Posted 29/03/09 12:52 AM If it is the emissions light, then yes it sould be fine to drive. Link to comment Share on other sites More sharing options...
Kermit Member 3 Member For: 15y 8m Posted 29/03/09 08:13 AM Share Posted 29/03/09 08:13 AM I got the NRMA guy out today through Ford's Roadside Assitance because the car is still under warranty and he was excellent. Took the time to diagnose the problem using my car's computer and his own display in his car and explain it to me in simple terms. It was a P1000 error which meant that a solenoid in an outlet valve on the turbo was not functioning properly, causing higher than usual pressure build up in the turbo. He was able to make the Malfunction Indicator Lamp icon go off and it has stayed off so far. He agreed Zap that the car would be OK to drive but suggested I don't get on the loud pedal too hard if it does come back on again. He also said that NRMA only ever come out to the XR6 Turbos for flat batteries or if someone has locked keys in the boot and that provided you meet the service expectations they are bullet proof which I was delighted to hear after the rocky start. Thanks for taking the time to offer your thoughts on this Zap and I hope this helps anyone else who might experience this problem some day. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 6m 1d Gender: Male Location: @ my laptop Posted 29/03/09 08:57 AM Share Posted 29/03/09 08:57 AM P1000 is a code relating to the ECU not reading enough data due to lack of distance, to assess the system.P1000 is not normally a problem code as such.It is normally set after a disconnected battery, reflashing the ECU or even just doing a reset on the ECU Link to comment Share on other sites More sharing options...
