  • Member For: 20y 5m 4d
Had a run against one last night on a private road that my mate Bracksy owns. Anyway, my T is stock and I'm not sure what numbers they put out, but we where pretty much nose to nose up until 80k's when I started to pull away. He didn't bother after that...
  • Replies 61
Posted Images
  • Member For: 22y 6m
Never run up against one but this is what the Porsche website says:
217 kW (295 bhp) at 6,250 rpm
0-100 km/h in 5.4 s
Top speed: 272 km/h
  • Member For: 21y 28d
Engine
Bore & Stroke: 96.0mm x 78.0mm
Displacement: 3387cc
Compression Ratio: 11.0:1
Fuel System: Multi-point Fuel Injection
Engine Block: 3.4 Litre, V6
Maximum Power: 217kW@6250rpm
Max Torque: 340Nm@4700rpm
Cylinders: 6
Valves: 4 per cylinder
Transmission: 6 speed manual
yup - sounds about right
...I had a run with a new 911 turbo last month
Engine
Displacement: 3600cc
Compression Ratio: 9.0:1
Engine Block: 3.6 Litre, V6
Maximum Power: 353kW
Max Torque: 620Nm
Cylinders: 6
I waved as I went past - I got the feeling he didnt enjoy having his $327k mid-life-crisis-mobile being whipped by some young punk in a seemingly stock $45k ute :crybaby:
The Porche Boxter S should be good for a 5.5 0-100ks and 13.6 1/4 mile and therefore should be able to account for your stock T relatively easily.
Funny that, the bloke in the Boxster wouldn't look over at the next set of lights....although, they are nice looking cars if you've got the money to throw at them...
  • Member For: 19y 2m 30d
my boss has the latest bmw m5 or whatever it is v10 pos. its like 200k or so.
he keeps saying that it will wipe my t off the road I say to him wednsday night at the creek and I will show u.
do I have a chance with 280 rwkw and a manual.
So does that mean he was a sh*t driver, or does my T have one of those engines that sometimes manages to come out of Ford with a little bit more power than what they should have. The reason I ask this is that I've managed to kill cars that I thought I shouldn't - a Maloo was a recent victim...either way I'm happy...I should get it dynoed one day to see how much it is pumping out...
  benmwhite said:
Engine
Cylinders: 6
Engine
Max Torque: 620Nm
Cylinders: 6
I waved as I went past - I got the feeling he didnt enjoy having his $327k mid-life-crisis-mobile being whipped by some young punk in a seemingly stock $45k ute :biggrin:
I take it your ute runs high 11's or at worst very low 12's then!
  • Crusty aviator
  • Member For: 21y 4d
I have some local experience of these and only a Boxter S should provide any degree of challenge and even then - on the straight bits you should be able to pull him off.
Bends or above 200kph the Porsche will show its pedigree.
Great little cars the emphasis being on little - room enough for a toothbrush but a great chassis.
Dingah
