byi Donating Members 159 Member For: 19y 8m 10d Posted 04/04/07 04:53 AM Share Posted 04/04/07 04:53 AM After winning a Ebay auction for a set of FPV gauges I have discovered that even though the gauges are VDO, without the correct resonators from FPV they are useless. It now appears that my only option is to swap the gauges around with an aftermarket solution. For those members who have done a similar undertaking any advice on the size of the gauges and any modifications that are required for correct fitment would greatly be appreciated.Cheers, Link to comment https://www.fordxr6turbo.com/forum/topic/33865-installing-aftermarket-gauges-in-a-fpv-pod/ Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 10d Posted 04/04/07 09:23 AM Share Posted 04/04/07 09:23 AM I think I can recall atleast 2 threads in the past month about this, dude seriously use the search function, the answers are there Link to comment https://www.fordxr6turbo.com/forum/topic/33865-installing-aftermarket-gauges-in-a-fpv-pod/#findComment-517320 Share on other sites More sharing options...
Kimberley Scott www.australianflag.org.au Donating Members 6,763 Member For: 19y 9m 13d Gender: Male Location: Brisbane Posted 04/04/07 09:49 AM Share Posted 04/04/07 09:49 AM Fat-Tony said: I think I can recall atleast 2 threads in the past month about this, dude seriously use the search function, the answers are there Dont be such a mean *beep* Fatz, a bloke with over 3000 posts should be a wizz at pointing a bloke in the right direction.ScottyPS post whores may not however. Link to comment https://www.fordxr6turbo.com/forum/topic/33865-installing-aftermarket-gauges-in-a-fpv-pod/#findComment-517333 Share on other sites More sharing options...
R UTE Donating Members 45 Member For: 21y 6m 8d Gender: Male Location: Perth Posted 04/04/07 10:54 AM Share Posted 04/04/07 10:54 AM Check this out worked for mehttp://www.fordxr6turbo.com/forum/index.ph...c=27098&hl= Link to comment https://www.fordxr6turbo.com/forum/topic/33865-installing-aftermarket-gauges-in-a-fpv-pod/#findComment-517364 Share on other sites More sharing options...
byi Donating Members 159 Member For: 19y 8m 10d Posted 04/04/07 12:58 PM Author Share Posted 04/04/07 12:58 PM R UTE said: Check this out worked for mehttp://www.fordxr6turbo.com/forum/index.ph...c=27098&hl=That is exactly what I am after. Thanks so much.Cheers, Link to comment https://www.fordxr6turbo.com/forum/topic/33865-installing-aftermarket-gauges-in-a-fpv-pod/#findComment-517429 Share on other sites More sharing options...
