falcon73 Member 163 Member For: 18y 10m 24d Posted 01/04/07 10:40 PM Share Posted 01/04/07 10:40 PM Morning all, as the heading suggest I have recently acquired a very low K BF Barra 190 N/A 6 motor complete, So considering this Barra 190 has done approx 150000 k's less my Barra 182 motor it would be silly not to change over.Question What would be involved and needed for the change over?The power output would be better being a Barra 190 as straight off I will have the extra 8kw then if we add all the mods that will definatley go higher than what it is now.Would I have to use the BF computer or will it connect straight up to the BA computer?I also picked up a 3.45 LSD as well so that will go in at the same time replacing the 3.23 so I will have a little gain there, all this will take a bit as I still have to clean and detail the motor, paint and polish some bits and pieces.While we have the motor out I am also considering if I should upgrade to a higher stall converter gotta try and sneak that in somehow, what is people recommendations.Any feedback would be good CheersJason Link to comment https://www.fordxr6turbo.com/forum/topic/33800-bf-barra-190-into-ba-my-next-project/ Share on other sites More sharing options...
falcon73 Member 163 Member For: 18y 10m 24d Posted 01/04/07 11:45 PM Author Share Posted 01/04/07 11:45 PM Tips on little go fast bits I can add to the motor like polishing or porting heads tricks with T/B's things like that would be much appreciated as well Link to comment https://www.fordxr6turbo.com/forum/topic/33800-bf-barra-190-into-ba-my-next-project/#findComment-516291 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 1m 16d Gender: Male Location: stanthorpe wine capital of qld. Posted 02/04/07 12:27 AM Share Posted 02/04/07 12:27 AM You will need to use the bf computor to get any gains.You will also find that wiring may be different if the bf motor and computor come from a 6speed auto car than it is different wiring to the bf 4 speed auto wiring.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/33800-bf-barra-190-into-ba-my-next-project/#findComment-516307 Share on other sites More sharing options...
falcon73 Member 163 Member For: 18y 10m 24d Posted 02/04/07 12:33 AM Author Share Posted 02/04/07 12:33 AM (edited) Ok maybe problem 1Come from a Bf with 6 speed manual.Still have the computer plus the complete wiring from the whole car including the engine and trans wiring Edited 02/04/07 12:34 AM by falcon73 Link to comment https://www.fordxr6turbo.com/forum/topic/33800-bf-barra-190-into-ba-my-next-project/#findComment-516310 Share on other sites More sharing options...
Kiwiforddvr Member 10 Member For: 13y 2m 9d Posted 29/03/12 07:58 PM Share Posted 29/03/12 07:58 PM Bf will plug directly into ba loom No s@&t it will bf has 2 knock sensors just take one off Couple dumb little things but keep ya other motor to swap bits until its finished Link to comment https://www.fordxr6turbo.com/forum/topic/33800-bf-barra-190-into-ba-my-next-project/#findComment-1216404 Share on other sites More sharing options...
