RUS531 RUS531 Donating Members 410 Member For: 18y 8m 15d Gender: Male Location: Emerald QLD Posted 01/04/07 02:11 PM Share Posted 01/04/07 02:11 PM I've been reading around some forum sites and have to ask it. Is replacing the ford thermostat with a cooler one have any advantage or disadvantage on motor performance, wear and tear, ect. I'm up in central Queensland so temps can get high especially in summer and we don't have the coolest of all nights either.Whats your opinion?Cheers Cameron Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/ Share on other sites More sharing options...
Guest Guests Posted 01/04/07 11:44 PM Share Posted 01/04/07 11:44 PM I've been reading around some forum sites and have to ask it. Is replacing the ford thermostat with a cooler one have any advantage or disadvantage on motor performance, wear and tear, ect. I'm up in central Queensland so temps can get high especially in summer and we don't have the coolest of all nights either.Whats your opinion?Cheers CameronI've lived in the Pilbara for the last 8 years and it's pretty standard practise there to replace thermostat with an 82 degree one. Once I did that in my Landcruiser the temp gauge never moved whereas before it would move with varying ambient temps and degree of hard work that I was doing. Never had a problem with it afterwards.When I had my edit done, Simon from Xtreme Ford Tuning did this too I believe and I noticed that my gauge sat lower again too. I would recommend calling him or any other reputable tuner and getting his point of view on this as it seems to be a good one. I would say go ahead and do it but I'm no expert whatsoever. It should be easy enough to revert back to old thermostat if you needed to.Just my opinion Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-516290 Share on other sites More sharing options...
ritzy Member 119 Member For: 18y 3m 15d Gender: Male Location: Lysterfield, Melbourne Posted 23/05/07 02:58 AM Share Posted 23/05/07 02:58 AM Any other thoughts or ideas ?? Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-536110 Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 10m 25d Posted 23/05/07 03:38 AM Share Posted 23/05/07 03:38 AM Any other thoughts or ideas ??Just what Rapid said, speak to a tuner as you will want to get the fans to come on sooner to offset the cooler thermostat.In short it's something you do when you get a custom edit tune. Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-536120 Share on other sites More sharing options...
MoreHPformyXR6 Member 15 Member For: 19y 3m 27d Posted 04/06/07 07:40 AM Share Posted 04/06/07 07:40 AM I live in Adelaide and am getting a custom tune donr this Friday 8/6/07 I spoke to my tuner re a cooler thermostat he reckons that it would be fine in summer but up more fuel consumption in winter as car will run a little richer. He suggested I leave it at this stage as I already have a 20% under drive and that should make run a wee bit cooler anyhow. Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-540496 Share on other sites More sharing options...
Guest Guests Posted 04/06/07 08:54 AM Share Posted 04/06/07 08:54 AM Any other thoughts or ideas ??You want Power?20% Performance Under Drives adds 9 rwkw for bugger all coin.Theres not many N/A XR6 or XT owners on AFF without Under Drives and not one unhappy owner.Its a must for the BA-BF N/A Inline 6 Cyl.Take a look at the Under Drive theads here on this forum or try AFF for details. Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-540526 Share on other sites More sharing options...
xr6_747 Member 30 Member For: 12y 9m 25d Gender: Male Posted 31/07/12 09:36 AM Share Posted 31/07/12 09:36 AM can I run no thermostat or will I damage somthing? Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-1273153 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 3d Gender: Male Location: Adelaide Posted 31/07/12 09:39 AM Share Posted 31/07/12 09:39 AM yes u can run no stat but yes u will phuc sh*t up in summer and it will be stone cold in winter either situation not good Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-1273158 Share on other sites More sharing options...
XR6menace BANNED Banned 1,462 Member For: 18y 6d Gender: Not Telling Location: banned Posted 31/07/12 10:10 AM Share Posted 31/07/12 10:10 AM (edited) Do not run without a stat mate .. when you decide to get up it the coolant doesnt stay in the rad long enough to cool down + the motor will stay in rich warm up loop when cold HTH.Go for a 82* if untuned or 71* with the fans brought in earlier via flashtuneDaz... Edited 31/07/12 10:11 AM by XR6menace Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-1273189 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 7d Gender: Male Location: @ my laptop Posted 31/07/12 10:14 AM Share Posted 31/07/12 10:14 AM 71 is too cold and can lead to oil not working correctly, oil temp needs to be to a certain temperature for it's additives to work 1 Link to comment https://www.fordxr6turbo.com/forum/topic/33792-cooler-thermostats/#findComment-1273196 Share on other sites More sharing options...
