  • Replies 24
  • Member For: 22y 2m 13d
that's a great time for a Unichip, close to one of the top private driver times with a Unichip if my memory serves me correctly. Well Done.
What power levels are you running, about 330-335rwkw at a guess?
Edited by xrdreaming
  • Member For: 19y 10m 6d
Thanks,
The car is running 338.9 RWKW
There is actually some thought of going to an edit as the unichip is probably running at its limit. We will probably get the auto sorted first and see how it goes, then take it from there
I would agree that you are just about on the limit of the Unichip, you will certainly gain a lot by going to an edit and that is speaking from experience.
I ran a similar time a couple of years back now with the same setup as you. The unichip was at it's limit and I changed over to edit.
  • Im the one and only
  • Member For: 20y 3m 4d
I ran the same time with my unichip and there was plenty left on the stall as I only stalled it to 2700 rpm.I was only running 300rwkw at the time to with AFR,s in the 11,s. and 12psi.I didnt have one problem with my unichip.
Edited by FPV TRANNY
  • Member For: 20y 10m 16d
are you running the 4speed? because a lot of the problems can be resolved by the edit software.
David
David
My stall could flare to 3300rpm but iit would go into limp mode.If I got it to stall to that,I should have run a low to mid 11 @120+mph.that's where the EDIT would have been better.
I had the same problem back then, it was Octorber 2004 when I ran my 11.7 @ 119, edit was not even around back then. I could only stall to about 2700rpm without limp mode kicking in.
Still the mph would have been close to the max the ute was going to run.
