gravelrash Member 211 Member For: 22y 4m 2d Gender: Male Location: Dalby, QLD Posted 22/07/07 10:07 AM Share Posted 22/07/07 10:07 AM kjoy064,I hav just odered one of these afterreading this thread. can you please send me a diagram on how to wire this to the 10 pin plug and also how you made yours lookin the project box.I plan on using mine with a single din dvd.cheers Greg Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-557496 Share on other sites More sharing options...
kjoy064 Member 276 Member For: 18y 1m 22d Gender: Male Location: WA Posted 23/07/07 12:17 AM Author Share Posted 23/07/07 12:17 AM Hi Greg,try this site here, http://www.fordmods.com/forums/documents.php?doc=38I just got the power for the unit from the lighter power source and then used a plastic box from dick smith yo out the unit in. I'll see how I go for a photo but I have hidden the unit under the dash. Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-557600 Share on other sites More sharing options...
gravelrash Member 211 Member For: 22y 4m 2d Gender: Male Location: Dalby, QLD Posted 24/07/07 10:08 AM Share Posted 24/07/07 10:08 AM I`m getting a little confused. the circuit (from france) shows a 9 pin plug but all the threads I have read includng the ford mods one show a 15 pin plug. What did you use? Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558065 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 9d Gender: Male Location: Victoria Posted 24/07/07 11:15 AM Share Posted 24/07/07 11:15 AM 9 pin is fine. I'm assuming the converter tells you what signals go to which pin?The 15 pin plug is used when connecting straight to a PC or laptop with no converter in place.The video converter I'm using comes with a cable with a 9 pin plug at one end and bare wires at the other. I just soldered up the connector for the ICC to the bare ends. Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558087 Share on other sites More sharing options...
kjoy064 Member 276 Member For: 18y 1m 22d Gender: Male Location: WA Posted 25/07/07 04:56 AM Author Share Posted 25/07/07 04:56 AM I`m getting a little confused. the circuit (from france) shows a 9 pin plug but all the threads I have read includng the ford mods one show a 15 pin plug. What did you use?Yeah Mate, have you got your parcel yet?Find my wiring diagram below.. The switch I used is a double poll unit so you can operate both the power from the lighter and the video from the flick of the switch Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558256 Share on other sites More sharing options...
gravelrash Member 211 Member For: 22y 4m 2d Gender: Male Location: Dalby, QLD Posted 25/07/07 11:30 AM Share Posted 25/07/07 11:30 AM thanks for the replys guys. no I havent got my parcel yet.I nearly have the cable finished but im stuck with two last wires to the 9 pin plug.trouble with the ground and sync wires. attached is a diagram can someone help me here Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558387 Share on other sites More sharing options...
kjoy064 Member 276 Member For: 18y 1m 22d Gender: Male Location: WA Posted 26/07/07 04:35 AM Author Share Posted 26/07/07 04:35 AM Hey mate, can I ask what the converter is for as it's from compisite (Yellow RCA) input and the output comes as a harnessPhilips CM8833-IIPhilips CM8833-II has quite similar specs to the monitor above (used in the same type of applications). Philips CM8833-II has a RGB connector which can accept both analogue and digital RGB signal. The RGB connector uses the following pinout: _____________\ 5 4 3 2 1 / \_9_8_7_6_/ -Pin- -RGB TTL- -RGB Analogue- 1 Ground Ground 2 Ground Ground 3 Red Red 4 Green Green 5 Blue Blue 6 Intensity Fast Blanking 7 Not used Composite Sync 8 H. Sync H. Sync 9 V. Sync V. Sync Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558557 Share on other sites More sharing options...
gravelrash Member 211 Member For: 22y 4m 2d Gender: Male Location: Dalby, QLD Posted 26/07/07 10:05 AM Share Posted 26/07/07 10:05 AM does this board from france come with a harness?I want to be able to connect my dvd player into this board via the video in rca jack and im guessing I needed to make the cable out of it to the the ICC.the dvd player has the usual video, audio l&r rca plugs. I would send the audio plugs to the aux in and the video to this board. out of the board and into the ICC.. have I got this right or have I got it wrong?do I have the wires wrong on the plug so far? as im confused about the sync and ground.cheers Greg Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558670 Share on other sites More sharing options...
kjoy064 Member 276 Member For: 18y 1m 22d Gender: Male Location: WA Posted 27/07/07 02:20 AM Author Share Posted 27/07/07 02:20 AM does this board from france come with a harness?I want to be able to connect my dvd player into this board via the video in rca jack and im guessing I needed to make the cable out of it to the the ICC.the dvd player has the usual video, audio l&r rca plugs. I would send the audio plugs to the aux in and the video to this board. out of the board and into the ICC.. have I got this right or have I got it wrong?do I have the wires wrong on the plug so far? as im confused about the sync and ground.cheers GregSpot on mate, the harnes that comes with the converter has leads that are about 30-45cm long with the 5 wires so just get your self and plug from a wrecker and plug her in Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558812 Share on other sites More sharing options...
gravelrash Member 211 Member For: 22y 4m 2d Gender: Male Location: Dalby, QLD Posted 27/07/07 10:34 AM Share Posted 27/07/07 10:34 AM well I`ll be buggered. I have the 10 pin EF-el plug already wired up to about a metre of shielded cable and 3 of the five wires already soldered to the 9 pin com plug on the other. I `spose that's what you get for being too organsied.Wish this bloody postie would hurry up and get his ass here from france.cheers, thanks for all the help.in my idle time (waiting) I have been devising a way to add a reverse camera and also a front spoiler camera to this system. I think I have it nutted.btw what size project box do I need? Link to comment https://www.fordxr6turbo.com/forum/topic/33731-dvd-video-to-rgb-convertor/page/2/#findComment-558959 Share on other sites More sharing options...
