EZ2CME Formerly XR6NA Member 3,512 Member For: 19y 5m 21d Gender: Male Location: Brisbane Posted 26/03/07 09:56 AM Share Posted 26/03/07 09:56 AM And I missed out by 2 months Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-513849 Share on other sites More sharing options...
Dyno Junkie Member 254 Member For: 18y 2m 4d Gender: Male Location: Ascot, Western Australia Posted 26/03/07 01:11 PM Share Posted 26/03/07 01:11 PM Headsex said: NO BA2 Turbos recieved the F6 rod.. Even the First BF's XR6Turbos didnt get the F6 rods. The only time the BF Turbo recieved the F6 rod was when the Turbo Territory became available in 06←So does this mean our Territory turbo has the better rods and springs, can anyone confirm? Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-513975 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 2m Posted 26/03/07 02:34 PM Share Posted 26/03/07 02:34 PM Dyno Junkie said: Headsex said: NO BA2 Turbos recieved the F6 rod.. Even the First BF's XR6Turbos didnt get the F6 rods. The only time the BF Turbo recieved the F6 rod was when the Turbo Territory became available in 06←So does this mean our Territory turbo has the better rods and springs, can anyone confirm?←Territory turbos came out after april 06 so the answer is yes Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-513992 Share on other sites More sharing options...
Max Power Member 381 Member For: 21y 18d Location: MENAI, NSW Posted 27/03/07 03:08 AM Author Share Posted 27/03/07 03:08 AM Bummer I just missed out (by 18 months)So what am I looking at as a bare bones approach to just getting some F6 rods installed? Obviously, you can do alot more while the motor is apart but just want the rods done so I can go to 375rwkw without sweating at redline (currently at 325)........maybe the oil pump also as Ive heard theyre a weak link.Fat-tony? Anyone? Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514079 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 28d Gender: Male Location: Perth, WA Posted 27/03/07 04:43 AM Share Posted 27/03/07 04:43 AM Max Power said: Bummer I just missed out (by 18 months)So what am I looking at as a bare bones approach to just getting some F6 rods installed? Obviously, you can do alot more while the motor is apart but just want the rods done so I can go to 375rwkw without sweating at redline (currently at 325)........maybe the oil pump also as Ive heard theyre a weak link.Fat-tony? Anyone?←You can't go to 375 rwkw safely with F6 rods, nor will your pistons last long at those power levels If you go beyond 350 rwkw's you need a properly built bottom end, with forged pistons and billet rods, and if you like revving high, a stronger oil pump Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514113 Share on other sites More sharing options...
Max Power Member 381 Member For: 21y 18d Location: MENAI, NSW Posted 27/03/07 08:33 AM Author Share Posted 27/03/07 08:33 AM Ninka said: Max Power said: Bummer I just missed out (by 18 months)So what am I looking at as a bare bones approach to just getting some F6 rods installed? Obviously, you can do alot more while the motor is apart but just want the rods done so I can go to 375rwkw without sweating at redline (currently at 325)........maybe the oil pump also as Ive heard theyre a weak link.Fat-tony? Anyone?←You can't go to 375 rwkw safely with F6 rods, nor will your pistons last long at those power levels If you go beyond 350 rwkw's you need a properly built bottom end, with forged pistons and billet rods, and if you like revving high, a stronger oil pump ←Sounds a bit conservative but its your opinion I guess. I tend to think that the F6 rods and standard pistons should be ok for 375rwkw then again I dont have a mechanic's licence - just based on what Ive heard around here. Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514183 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 28d Gender: Male Location: Perth, WA Posted 27/03/07 08:44 AM Share Posted 27/03/07 08:44 AM Max Power said: Ninka said: Max Power said: Bummer I just missed out (by 18 months)So what am I looking at as a bare bones approach to just getting some F6 rods installed? Obviously, you can do alot more while the motor is apart but just want the rods done so I can go to 375rwkw without sweating at redline (currently at 325)........maybe the oil pump also as Ive heard theyre a weak link.Fat-tony? Anyone?←You can't go to 375 rwkw safely with F6 rods, nor will your pistons last long at those power levels If you go beyond 350 rwkw's you need a properly built bottom end, with forged pistons and billet rods, and if you like revving high, a stronger oil pump ←Sounds a bit conservative but its your opinion I guess. I tend to think that the F6 rods and standard pistons should be ok for 375rwkw then again I dont have a mechanic's licence - just based on what Ive heard around here.←Think as you like, it's your car and wallet Just hope it doesn't catch fire when it spills its guts and all that oil sprays all over the exhaust.Ask anybody here who has 1/2 an idea about these engines, if they consider 375rwkw safe with stock pistons and rods Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514190 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 9m 2d Gender: Male Location: Zombie Birdhouse Posted 27/03/07 11:08 AM Share Posted 27/03/07 11:08 AM Hence my 350rwkw will remain as is Still no guarantees though. Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514270 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 4m 28d Gender: Male Location: Brisbane Posted 27/03/07 11:13 AM Share Posted 27/03/07 11:13 AM I can't say that I know that much technically but I was talking to my local tuner regarding my car and he won't push it past 350rwkw without doing rods and pistons so I would say Ninka is right in what he is saying. Better to be safe than sorry. Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514275 Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 4m 28d Gender: Male Location: Perth, WA Posted 27/03/07 11:56 AM Share Posted 27/03/07 11:56 AM mbjunior99 said: I can't say that I know that much technically but I was talking to my local tuner regarding my car and he won't push it past 350rwkw without doing rods and pistons so I would say Ninka is right in what he is saying. Better to be safe than sorry.←Woo-hoo, somebody gets it May you live long and have many children Link to comment https://www.fordxr6turbo.com/forum/topic/33593-standard-ba2-rods-are-they-same-as-f6/page/2/#findComment-514295 Share on other sites More sharing options...
