  • Member For: 18y 11m 9d
hey guys half way through installing walbro pump
have original assembly out currently stuck pulling the assembly apart see image how do I do this and get the fuel lines off undamaged
https://www.fordxr6turbo.com/forum/topic/33530-walbro-install-help/
  • Replies 33
  • Created
  • Last Reply
Top Posters In This Topic
  • Member For: 22y 2m 14d
The fuel lines usually break and you need to buy new ones, either originals or use fuel hose designed to be in tank. I don't think you will be able to re use them.
finally got the pump finished and back together at 4:30
note to anyone else going to do this it's harder than it sounds
also buy new submersible fuel line beforehand would've made it 100x easier
Edited by qwigybo
took the car for a test run, seems alright off boost
but seems to be flooding it's anus off above 2500rpm I'm guessing this would be normal for an un-edited T ?
  • Member For: 20y 11m 14d
If it feels like you are losing power , you may have a fuel leak at the hoses connected to the pump or the housing.
you would not get a power increase as the fuel reg still lets go at the same point,
all that the new pump is doing is holding the pressure to the fuel reg and not dropping off like the std one does.
