  • Powered by Ford's 3.7 V6 = Zoom Zoom Zoom!
  • Member For: 20y 6m 5d
Out of warranty, nearly 4 years old :sleepystuff:
And only 20,000kms :gfight:
Clarke
  • Replies 23
  • Just because it is, doesn't mean it should be.....
  • Member For: 20y 7m 24d
  • Gender: Female
CLARKEY...
:buttrock::roflmbo:
thought for a minute there I was reading the script for National Lampoons..
shaz
and why oh why didn't you get extended warranty :blink:
  • My new toy
  • Member For: 22y 14d
Hey clark I can help I know how to fix this so it does not happen again.
Ian
PS that is I know how to fix the bonnet catch.
  • Mushroom
  • Member For: 20y 11m 21d
  mbjunior99 said:
You need to get out and drive it a bit more ... that's only 5000km a year :blink:
Thanks for that Capt. Obvious. :gooff:
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 9m
My mate just got a BF XR8 about 1 month ago and when I asked him to open the bonnet, the whole brown plastic lever inside the car came off. Just snapped off. But thank goodness, the cable was still attached to it and so we just pulled the plastic lever with the cable and it still popped open the bonnet.
  • 1 month later...
  • Member For: 18y 2m
  Robit28 said:
Now take it into Ford and get them to replace it under warranty, this is a known problem and they have a new, stronger bonnet release made for this problem.
Rob.
Yes it is a known problem, Ive done a billion of them, there was a revised bonnet cable, you will notice that one has a glossy finish and the other has a mat type finish, yesterday when I did one parts department gave me a bf cable to fit to ba, much better and no dramas in fittment, just slightly more meat on the rear clip that attatches to the rear of the fuse panel. A tip for you all with your bonnet release, which surprise surprise, not many ford mehcanics do (do to a published fix being in place from ford, limiting service action) is to remove the return spring in the bonnet latch and stretch is slightly, then refit for testing, then if necessary tweak a bit more. not really difficult in know, but makes a huge difference.
cheers
