Bf Xr6 6 Speed Gearbox Cost
falcon73
  • Member For: 17y 9m 8d
because they came out of a tractor! apart from the obvious bellhousing difference, the commo version of the T56 has diferent linkages somewhere, and it only has single syncros on forward gears, as well as a longer gear throw
So No..
  • Member For: 19y 11m 10d
From all the previous posts there are four different boxes:
1. XR6T
2. XR6
3. XR8
4. Expensive Daewoo V8s
They have different splines, lengths, shifter locations etc etc
I would like to know if any of the bellhousings bolt up to the XR6T block as I want a cheaper box than the turbo one for my Escort when it gets an XR6T motor.
Edited by cobrav8
  • 8 years later...
  • Member For: 12y 8m 9d
On 18/03/2007 at 9:00 PM, Ninka said:
Hiddeous and I just fitted a 6 speed manual to xr06t's BA 5 speed car yesterday.
No major problems, you just need the complete trans with cross member etc., shifter, yoke and some additional wiring for the reverse inhibitor, and it will all bolt in.
We spent about 6 hours doing the job.
So retune required?
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 24d
good thread mine :mole:
In short, yes... just to switch the ECU's program/setup from auto to manual. No other tuning is necessary.
  • Moar Powar Babeh
  • Member For: 19y 5m 11d
Not when going from manual to manual.
Also going from Auto to Manual requires a touch more than just that ^
To do properly gear ratios need to set, torque management and idle parametes need to be adjust plus a couple of other things.
  • Site Developer
1 minute ago, Ralph Wiggum said:
properly
This is the point. To do it properly, you'd want a full tune and setup done to suit the new setup... but to just "get it done", is another matter.
