  • Member For: 19y 10m 21d
thankz guys for all the positive comments, I will take some more pics and load them up soon.
rims came from foose usa as everyone knows that, it was imported through tech tyres as was mentioned b4. toke some time but seems like its worth it.
anywayz thanks all
  • Replies 39
  • Member For: 18y 11m 23d
anywayz thanks all
Hi Muzza 420,
Do you think 285's will fit on the back or are things quite tight with the 275's?
How much room is there once you roll the guards?
Justin
  86gav said:
10's ON THE BACK!!! OMG  that is awesome, dont know how our gonna go lowerin it though, mine is lowered on 225/20s and only just clear the guards.
Cheers
Gav
These car's even when stock really need a wider tyre, why would you want to go with a smaller tyre again. Im running 265's on the std rims but would love a 295-3o5 rear.
although width of the tyre is good, its not gonna solve your traction issues you actually need a better tyre too. For example if you have 10" wide "wang ping chi" brand tyres its not really gona help no matter how wide.
Muzza
  2MUCHKW said:
Hi Muzza 420,
Justin
hi justin,
I am actually in the process of finding out if I can fit the 285's and looking if it will be a comfortable fit.. I will update you once I find out.
regards
Muzza
Hi Muzza,
Brian runs 285/35/19 Pirelli Corsa's and raves about their grip and performance but dont I know if they are available in 20". Be interesting to see if your rims have the same offset as Brians for he has to run 2 degrees negetive camber for guard clearance.
Look forward to your findings
Generally the cheap rubber like the afore mentioned ping pong brand don't come in the wider widths, but I know what your saying. Quality makes a hell of a difference.
Cheers
Justin
  • 2 months later...
  • Member For: 19y 1m 14d
  muzza420 said:
hi justin,
regards
Muzza
Hi Muzza,
I'm fairly new to this forum. I have a M1 BF Typhoon and run 285x30x19 on the rears. I had to roll the guards and add 1 degree negative camber. The tyres touch slightly at speed on road undulations but this is partly caused by the soft suspension. I'm changing to higher rated Kings springs + Bilsteins soon, so that problem should be corrected.
