antigravity Member 332 Member For: 18y 3m 14d Gender: Male Location: Sunshine Coast!!!! QLD Posted 15/03/07 05:00 AM Share Posted 15/03/07 05:00 AM Got another problem with the T.. :( It was leaking power steering fluid (a leaky hose), and since then, its been making a 'cracking' noise when turning the steering wheel.It seems to be working fine, and the fluid is topped up. The crack usually occurs when turning it away from 'centre'. So if the wheels are pointing straight, and I turn the steering left/right, it'll crack. If turn it further from that point, the cracking is intermitten and seems random. I'm hoping my steering pump isn't buggered... any ideas? Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 9d Gender: Male Location: Brisbane Posted 15/03/07 05:03 AM Share Posted 15/03/07 05:03 AM Is it only at low speed? or speed doesn't affect it? Link to comment Share on other sites More sharing options...
wilko117 Member 67 Member For: 18y 10m 10d Gender: Male Location: Melbourne Posted 15/03/07 05:07 AM Share Posted 15/03/07 05:07 AM yeah minde did that and they said cause the rack was loose or something. they fixed at ford in my service. I have had three xr's and they have all done it. someone also said it can be air in the lines or something not to sure Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 9d Gender: Male Location: Brisbane Posted 15/03/07 05:15 AM Share Posted 15/03/07 05:15 AM I had the problem on my BA XR6 Turbo where it would creak/crack when turning at low speeds. Ford service fixed it by doing something to the steering rack. Not sure exactly what anymore. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 6d Gender: Male Location: Brisbane Posted 15/03/07 05:22 AM Share Posted 15/03/07 05:22 AM They try to fix it by doing a few figure 8's, if that doesn't work they add a few washers and countersink a few holes on the steering rack. Bit hit n' miss like most Ford solutions actually Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 9d Gender: Male Location: Brisbane Posted 15/03/07 05:24 AM Share Posted 15/03/07 05:24 AM They try to fix it by doing a few figure 8's, if that doesn't work they add a few washers and countersink a few holes on the steering rack. Bit hit n' miss like most Ford solutions actually ←That was actually the fix for the steering shudder ... I had that one too on my BA Link to comment Share on other sites More sharing options...
Blonk Iconoclast Donating Members 4,330 Member For: 20y 3m 4d Gender: Male Location: CH Posted 15/03/07 05:26 AM Share Posted 15/03/07 05:26 AM Loose rack standard problem.. Get them to put some locktight on the bolts when they tighten it.. Link to comment Share on other sites More sharing options...
PROXRT Member 105 Member For: 17y 9m 26d Posted 15/03/07 07:16 AM Share Posted 15/03/07 07:16 AM loosen your rack and pull the rack to ward the rear of your car clean around the cross member and rack where they bolt together and and some sort of lubricant like rubber grease then tension the rack to 80nm make sure its tensioned and the creak should go away. good luck Link to comment Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 18y 10m 22d Gender: Male Location: Sydney Posted 16/03/07 12:34 AM Share Posted 16/03/07 12:34 AM It's not confined to XRs .. my brothers SR does it, and my Dad's BA trayback ute is starting to do it too (only 17000kms on the ute) Link to comment Share on other sites More sharing options...
mickbundy Member 243 Member For: 20y 6m 8d Location: W.A Posted 21/03/07 12:37 PM Share Posted 21/03/07 12:37 PM It's not confined to XRs .. my brothers SR does it, and my Dad's BA trayback ute is starting to do it too (only 17000kms on the ute)←My XR6T Ute done the same the mate at the dealership said they just have reshim it all was goodNow the new ute is doing it Link to comment Share on other sites More sharing options...
