groper Member 611 Member For: 17y 11m 21d Posted 05/03/07 11:50 AM Share Posted 05/03/07 11:50 AM just trying to figure out whats wrong with the stock item, and why it needs to be replaced ahem, besides us loving to spend money... why can t we just modify what the actuator `sees` with a simple ball and spring valve or bleed valve for that matter, set at whatever psi you desire? Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 17y 11m 21d Posted 05/03/07 12:36 PM Author Share Posted 05/03/07 12:36 PM ok I found something, seems like the stock actuator cant open the swing valve far enough (not enough throw) to allow suffient bypass at higher hp flow rates, to control boost, does this sound right? hence the porting mod and bigger swing valve usually done at same time for same reason...so basically you could use bleed valve inline with actuator if you only wanted to change boost level, it just gets hard to control if your making big hp? Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 9m Gender: Male Location: stanthorpe wine capital of qld. Posted 05/03/07 06:50 PM Share Posted 05/03/07 06:50 PM Bleed valve will not work on the xr6t as the computor will have a hissy fit and go into over boost if it sees a boost level outside it's set limits.that's why you need edit or a piggy back system to control the boost.As for the actuator when you are going for more boost it helps to control boost better with a higher boost unit.Ian Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 17y 11m 21d Posted 06/03/07 05:26 AM Author Share Posted 06/03/07 05:26 AM yep I understand the computer issue, im assuming you have already done that. what im saying is, why do we need a $200 actuator to run more boost when a $20 bleed valve should do the trick? Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 9m 29d Gender: Male Location: nsw Posted 06/03/07 05:30 AM Share Posted 06/03/07 05:30 AM (edited) if u have an edit/ flash tuner u dont need anything.the factory fitted boost control solenoid is run by the computer, the only problem is that if u command too much boost it will spike. that's why we mod the wgate so as to hold steady at 15 18 20 psi.you dont need an actuator to run more boost but if u want 15 psi u will need one.on mine im running a bleed valve and I can get 9 psi with no spike but if I go any more it hits 15 and dropps off to 12. Edited 06/03/07 05:34 AM by hooverman Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 17y 11m 21d Posted 06/03/07 06:25 AM Author Share Posted 06/03/07 06:25 AM then why do people buy different actuators when it seems the problem is the wastegate size? why do we need one at 15psi? Link to comment Share on other sites More sharing options...
BFHOON Donating Members 1,932 Member For: 18y 9m 29d Gender: Male Location: nsw Posted 06/03/07 06:32 AM Share Posted 06/03/07 06:32 AM the stock actuator is rated at 4.5 psi.running this at 15 psi is way out of its opperating duty cycle.to command 15 psi on the program its around 100% howerver if u fit a 12 psi actuator its back to 50%or so, making it easier to controll boost.there are other reasons also. im no expert. Link to comment Share on other sites More sharing options...
groper Member 611 Member For: 17y 11m 21d Posted 06/03/07 06:50 AM Author Share Posted 06/03/07 06:50 AM what do you mean duty cycle? how could something be out of its duty cycle when all it does is open and close a valve? does it operate electrically or pnumatically? Link to comment Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 21y 9m Gender: Male Location: stanthorpe wine capital of qld. Posted 06/03/07 07:30 AM Share Posted 06/03/07 07:30 AM There is a boost solinord which is controlled by the computor this is where the duty cycle side of things comes in.The computor controlls the actuator via this solinord by pulsing the solinord.Ian Link to comment Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 30d Gender: Male Location: Brisbane Posted 06/03/07 07:32 AM Share Posted 06/03/07 07:32 AM I'm lost .... just glad it all works Link to comment Share on other sites More sharing options...
