dingah2 Crusty aviator Member 846 Member For: 20y 7m 21d Gender: Male Location: ACT Posted 11/03/07 07:49 AM Share Posted 11/03/07 07:49 AM (edited) A fair bit of exprience with these setups.DBA 400 slotted (not cross-drilled which then become cross-cracked) and Racebrakes RB74 competition pads $160 a set for Premos - far cheaper than Ferodos etc - they have a higher temp rating than almost anything available but are fine for street use. Have never managed to fade them using Motul race spec fluid and braided lines. They are superior to Ultimates without quite as much cold bite and do not produce as much dust. Failing the RB74s use Bendix Ultimates or Red EBC, good cold bite Ultimates will eventually fall apart long before the RB74s but it takes some doing. Do not recommend Lucas as they are a cheap alternative and QFMs are a better cheap alternative.Dingah Edited 11/03/07 07:49 AM by dingah2 Link to comment Share on other sites More sharing options...
Guest FatBAt Guests Posted 11/03/07 09:09 PM Share Posted 11/03/07 09:09 PM As Stang first posted. he didn't want a pad that was hard on discs. The Ultimates (and I assume the EBC's) are hard on discs. After 2 years running Ultimates my discs were stuffed.QFM's LTM003's on the other hand have realistic wear on discs and still perform very good for (street) spirited driving. (AND) are rated to 650deg as opposed to Ultimates at 550deg.Cheers Link to comment Share on other sites More sharing options...
Guest FatBAt Guests Posted 12/03/07 03:15 AM Share Posted 12/03/07 03:15 AM QFM's LTM003's on the other hand have realistic wear on discs and still perform very good for (street) spirited driving. (AND) are rated to 650deg as opposed to Ultimates at 550deg.Cheers←CorrectionLTM003 are rated to 560deg....not 650.cheers Link to comment Share on other sites More sharing options...
PDIDDY Senior Member Member 159 Member For: 18y 3m 14d Gender: Male Posted 25/03/07 10:45 PM Share Posted 25/03/07 10:45 PM What can I say about the service from Tyronne at Stopmaster? What brilliant service. Couldn't get my pads and line out of Newcastle in time to arrive last Friday, so he brought them up with him on the weekend. Picked the gear up at Brookwater golf course yesterday, before he tee'd off.Could not have been a nicer bloke or a bigger help.Well done mate. You don't find service like that anymore. Can't reccommend enough. Link to comment Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 20d Location: Melbourne Posted 26/03/07 08:07 AM Author Share Posted 26/03/07 08:07 AM I am reading this thread in intrest and thank all who have posted. I have my disc just have to buy the pads.I am in melb any distributors I should look at or just try repco and the likes. Link to comment Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 20d Location: Melbourne Posted 26/03/07 08:12 AM Author Share Posted 26/03/07 08:12 AM As Stang first posted. he didn't want a pad that was hard on discs. The Ultimates (and I assume the EBC's) are hard on discs. After 2 years running Ultimates my discs were stuffed.QFM's LTM003's on the other hand have realistic wear on discs and still perform very good for (street) spirited driving. (AND) are rated to 650deg as opposed to Ultimates at 550deg.Cheers←So the ebc`s and the ultimates are hard on disc`s.To give you an idea I drove with the factory std disc and pads for 3 years and developed shudder only twice the 2nd time being dec 2006, they changed my pads under warranty but the dust is a f&*&^^&** nightmare. Link to comment Share on other sites More sharing options...
dalts Member 755 Member For: 18y 8m 14d Gender: Male Location: brisbane Posted 26/03/07 08:27 AM Share Posted 26/03/07 08:27 AM well ive had my ebc reds on for a month now stopping is alot better then the ultimate and the big suprise is the lack of dust they hardly have any,compared to the ulitimates they were disgracefulcheers lee Link to comment Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 20d Location: Melbourne Posted 30/03/07 01:00 PM Author Share Posted 30/03/07 01:00 PM I have made some further enquiries regarding the QFM pads.The pads that I run have been co-developed by QFM and Tyrone Duggan at Stopmaster Brakes at Gateshead. Newcastle).They are part No. LTM 003 with a price tag of $85 per set including a shim set. Tyrone will post anywhere in Aus for (circa) $10.Tyrone also recommended a set of steel braided hoses at $150 per pair. This he says reduces the flex that is created in the lines that Ford use.What is the shim kit ?The steel braided lines , I need front and back yeah (so these meet adr approval?)Sorry if I`m being anal but like toa sk questions. Link to comment Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 20d Location: Melbourne Posted 11/04/07 10:45 AM Author Share Posted 11/04/07 10:45 AM Are the ltm003 ok for a track day? once a blue moon, how will they hold up.I have also noticed that there is a QFM k750 available it says they are designed for extreme use from the Street to the TrackK750 brake pads will perform from dead cold to 780 Deg C.Are these a better pad, will they be as easy on the disc as the ltm003?,will I need a shim kit?, what is a shim kit?,do they bite good when cold or do you have to get them warm.Hello anyone? Link to comment Share on other sites More sharing options...
stang Donating Members 1,353 Member For: 21y 20d Location: Melbourne Posted 15/04/07 09:10 AM Author Share Posted 15/04/07 09:10 AM Ok guys as you know have been thinking about the lmt003 and the K750 asked the question and this was the response what do you guys think see below.hello pete,> the qfm ltm003 are rated at 600 deg C while the k750 are at 780 > deg C. they both have the same cold co-effecient so your byte will be > the same but the k750 can handle much more punishment.> > The ltm003 where designed for the high end street use only, the > k750 were also designed for the high end street use with the added > extra performance to handle light track racing, eg: 5-10 laps at > sandown not 40.> > the k750 create 10% more dust than the ltm003.> > to sum up the k750 are qfm's highest street to track brake pad the > next step from this are full racing compounds that are not designed > for the street. Link to comment Share on other sites More sharing options...
