  • Member For: 18y 11m 10d
Hmm, I get 13psi 1st 2nd 3rd 4th... I have changed the way the turbo breathes so maybe that is a large factor... interesting though
  • Member For: 19y 1m 6d
mabee an auto will see full boost in first as the gear is bigger with more time on the gas.
in a manual 1st gear is over before it started.
  • Get on the end of it.....
  • Member For: 19y 4m 14d
:blush:
  Chris xr6 said:
The higher load on the engine in higher gears creates more heat and pressure in the exhaust gasses allowing the turbo to make more or full boost. Generally in first there will not be enough load on the engine to make full boost.
cheers mate . u would think it would be the same all the way through :w00t2:
  • My engine bay is Bionic
  • Member For: 19y 1m 11d
I been having a little surge problem first thing in the morning going from second to third, real brief and goes away quick. May be diff to what you on about.
