  • Member For: 21y 4m 8d
Interestign reply from Nulon. When I was a mechanic 20 years ago we used to have every man and his dog come to the workshop and try to sell us additives. I must admit that Nulon was the workshop choice, but I was informed about the coating problem by several "experts" mostly the ones selling their additives.
I guess they must be doing something right if they are still around. I can attest to their products working in the gearbox as we had a totally dry gearbox run for 5km after a rock cracked the housing.
I was looking at their oil range recently and it looked good and affordable.
  • Member For: 21y 2m 3d
Yeah, I must admit that I was a bit sceptical of the additive stuff myself until I did a bit of reading about their inhouse tests in the past. They once drove a VC Commonwhore from Syd to Melb after completely draining the oil out. The oil had been treated with one of their PTFE additives and run for a period of time, before it was drained. Incredible when you think about it.
I'm currently on my first fill of their top shelf 10W-40 synth. By all acounts, I'm a very happy camper. I only paid $39 per 5lt pack as well :blush:
  • Member For: 22y 6m 14d
  Spruce said:
I'm currently on my first fill of their top shelf 10W-40 synth. By all acounts, I'm a very happy camper. I only paid $39 per 5lt pack as well :crybaby:
Hey Spruce, Where did you get the 10W40 from?
I was going to use that last time but couldn't find it in any of my normal shops.
And for what its worth, I used to use Nulon Performance Engine Treatment in my XE and it seamed to make the engine run much more smoothly and quietly. Dont know if it had any actual friction reducing benefits but it seamed a lot nicer running :gooff::bum:
Edited by Ghia
  • Member For: 19y 9m 17d
that's it then, nulon oil and additive in next oil and filter replacement. If it helps make the engine quiter I'm all for it.
What about the e30. Anyone using the longterm treatment?
  • www.australianflag.org.au
  • Member For: 19y 11m 5d
I found the Nulon oil at Autobarn, been in for 5000km, does the same job as Castrol edge, from where I sit. If this remains the case then its Aussie, its priced well. So I will stick with it. Cannot see the value of PTFE additives for engines, Gearbox and Diff yess, but engine needs good oil and regular changes.
My thoughts only.
Scotty
I'm in SA at the moment, and had to hunt for it myself. Autobarn supposedly stock it, but I only found one pack. If you go to the Nulon website, they have a store locator on one of their sub menus.
No argument with the good oil and regular changes, that's a given. For me, the PTFE and its residual coating is an insurance thing. I've personally had it save one engine as I said, so in the event that I push the envelope and destroy my oil pump, I'm happy that my oil starved donk will have more of a fighting chance than it otherwise would have in such an event. To each his own.
Edited by Spruce
  • Tractor Driver
  • Member For: 19y 4m 13d
What temps does our oil see (highest would be the turbo bearings maybe?)? PTFE (Teflon is a brand-name) melts at 327 deg C and thermal decomposition starts at 400 deg C.
Yeah, I used their 'Store Locator' and got stuff all results. Autobarn has been mentioned I'll give them a go. Thanks!
And on Loopism's data there I'd be very interested to hear where that heads - I've got no idea what temp's oil gets too.
