did_4m41 Member 26 Member For: 17y 9m Posted 03/03/07 11:53 PM Share Posted 03/03/07 11:53 PM (edited) emm, becoz of my work, yes, she has to sleep for quite sometime in the garage.previously, I dun drive my pajero for almost two months and nothing happen, I mean I still able to start the car without any problem. my fren car, some how, their battery will die or watever...if I dun run my car for such long time, is it bad to the car? Edited 03/03/07 11:56 PM by did_4m41 Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 8m 8d Gender: Male Location: Sydney Posted 04/03/07 12:11 AM Share Posted 04/03/07 12:11 AM I would say nothing would happen, but disconnecting the batter will prevent any trickle down of the battery.Make sure you also do not have any ethenol based fuel in the tank.A month is not long, a year would be. Link to comment Share on other sites More sharing options...
EZ2CME Formerly XR6NA Member 3,512 Member For: 18y 10m 22d Gender: Male Location: Brisbane Posted 04/03/07 12:40 AM Share Posted 04/03/07 12:40 AM When I left the AU in the garage for 2 weeks while I was away on holidays it ran a little rough for a few seconds but was fine after that. Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 3m 15d Gender: Male Location: The 8th Dimension Posted 04/03/07 01:24 AM Share Posted 04/03/07 01:24 AM When you go to start the car after you come back, hold the accelerator pedal to the floor. The engine will crank over but not start, do this for a few seconds to get the oil flowing around the engine before starting the car normally Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 21y 8m 21d Gender: Male Location: Sydney Posted 04/03/07 06:33 AM Share Posted 04/03/07 06:33 AM It wont go as well as it normally does, the petrol will be stale.It will crank fine, as long as you have no extra accessories draining the battery. Link to comment Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 4m 3d Location: Canberra Posted 04/03/07 09:32 AM Share Posted 04/03/07 09:32 AM When you go to start the car after you come back, hold the accelerator pedal to the floor. The engine will crank over but not start, do this for a few seconds to get the oil flowing around the engine before starting the car normally←I was informed not to push the accelerator in an injected car if the car is not running have I been mis-informed?? Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 8m 8d Gender: Male Location: Sydney Posted 04/03/07 09:47 AM Share Posted 04/03/07 09:47 AM The BA/BF have a feature called flood clearing. If you put your foot flat to the floor and crank, the car will not start.This is handy if you are wanting to build oil pressure after a change or if the car has sat unused for a long time. It is also usefull if you flood the motor. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 5m 27d Gender: Male Location: Brisbane Posted 04/03/07 11:43 AM Share Posted 04/03/07 11:43 AM Doesn't it re-sync the cam phasing or something.....as in isn't that the intent of the feature? Link to comment Share on other sites More sharing options...
phantomchic Just because it is, doesn't mean it should be..... Lifetime Members 14,092 Member For: 20y 1m 10d Gender: Female Location: Noosa QLD Posted 04/03/07 01:50 PM Share Posted 04/03/07 01:50 PM the Phantom sat in his bedroom for close on 3 months, with few very intermittent drives. he fired up as good as always no problems at all shaz Link to comment Share on other sites More sharing options...
Ford_Power Member 798 Member For: 21y 6m 21d Posted 05/03/07 05:53 AM Share Posted 05/03/07 05:53 AM Doesn't it re-sync the cam phasing or something.....as in isn't that the intent of the feature? ←that's exactly what it is for. It also is used to clean the small oil galleries with a pulsing action to attempt to dislodge any small dirt or grit that may be in there affecting cam phasing operation. Link to comment Share on other sites More sharing options...
