Giant Leap
Ninka
  • Member For: 22y 20d
Ninka.
I am very impressed with your little handy work,Takes allot of time to do something like that.When you have got your final dyno figures make sure you post them up on this thread.I would be very interested to see the AFRatios before and after.This way of modifying sounds the way to go.
I wonder why your car was only showing 173 kw before mods were done?.Seems to be a few variations in car outputs for all the Ts.Maybe your boost was only set on the low side of 6psi.Get the tuner to print your boost curve if possible as well.
Well done mate,Have to get this stuff done I think.I will blame you for this decision.
  • Replies 38
Posted Images
  • ....Time to lay this fairytale aside......
  • Member For: 21y 11m 5d
  • Location: In the Ferry on the River Styx, not getting out just yet!
Nice work Ninka, hope to see it in 'the flesh' next Friday night.
I've got the 'Bird' booked into Perth Exhaust next Friday and getting also the 3" straight through, hi flow cat stainless steel system and the BMC carbon filter fitted as well, shekyls outlayed $1850 (incl GST and fitting).
Dyno before and after. And will post pics of as much as possible.
  • Member For: 22y 1m 23d
We did the final Dyno testing today, and anded up with 200 KW exactly @ 8.3 PSI.
The problem with optimising further, is that after the first run, the ECU detects higher oil temp. and start winding things back.
Second run the boost is significantly lower, and if we keep trying, it just gets slower and slower.
It appears that oil cooler is a must if top level performance is to be maintained over longer periods, to keep the oil temp. under control.
If you read some of the shootout test done with the XR6T, you will have noticed that they also only got 1 or 2 good runs, and from there the XR6T just got slower and slower.
Last night (cool night at 10 degrees C.), I went out on the outskirts of Perth to test my brakes (they have a pretty bad shudder), and did 4 runs from 0 kmh to fairly high (not promoting speeding here), then hit the brakes hard, floored it again and so on.
By the last run, I could hardly feel the CAPA modification, as I imagine the boost had been reduced to near standard levels by the ECM.
Cooling is definitely an issue on this car, and one that must be addressed if you plan to increase the power.
I plan to fit water spray and oil cooler at the end of winter.
Here's the long awaited Dyno for my XR6T.
The red lines are before and the blue after mods.
The "M" line is boost, and the "P" line is power.
  • FORD FORD FORD
  • Member For: 21y 10m 29d
Well done Ninka,
I'm wondering wether you've got a tow kit & therefore a oil cooler for the auto. There's also a story that the engine has a oil temp safety cut off but it's supposed to just shut the engine down rather than reduce power. Good luck with your modifications & increased Grunt.
Scotty
  • Member For: 22y 28d
First the "Boost Box" which really is a combination electronic and pneumatic controller, which takes control of the boost, while gently stroking the ECU and convincing it that boost is OK and within limits :lol:
so basically what we need a bleed valve for the turbo to raise boost and then something to trick the pressure senser that everything is still stock....
then everything you take it into be service you remove the valve and ford would be nun the wiser....
correct??
Dave.
correct??
Dave.
I guess if you wanted to go to that trouble you could.
There are however a couple of wires spliced into the wiring harness, but I guss if you wanted, you could assemble them all in a plug, then all you would have to do is unplug the "boost box" and re-establish the hose conections to the wastegate.
