Xr6t Serious Boost Problems
myxr6twpn
  • Member For: 19y 9m 9d
make sure to check exhaust manifold and turbo bolts as many members have found these to be loose or missing altogether. My turbo has currently only got 3 bolts. My car was failing to make any real power with good boost was down on factory levels and it turned out to be a fault ECU that Ford replaced under warranty, went back in to the tuner ran the same tune 292RWKW
  • Member For: 18y 2m 26d
after all the headaches I finally found the problem after looking at it closely some fcukhead bent the actuator rod so the car wouldnt make boost, why??? I wish knew... anyway so I bent the actuator back in place, now the engine makes 10psi all the time, goes excellent... back for a proper retune... just a question do these actuators come off seperate? or does the turbo have to come with it?? im gona buy a new one to be safe... thanks for all the help guys...cheers rocky
