turbotrana Member 2,586 Member For: 22y 1m 5d Gender: Male Posted 11/03/08 12:39 PM Share Posted 11/03/08 12:39 PM There may be several different vibrations. In my wifes fairmont the front wheel bearings were one vibration and I even trace the wheel bearings to the brake shudder as since the wheel bearings were replaced by ford no hint of shudder.The second vibration was tailshaft related. Had it balanced and it improved but still a slight vib at 95kph. They ripped the rear end apart trying to solve it but its still there. I've given up on it cause its the wifes car and she doesnt notice it. If I drove all the time it would drive me bonkers. Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-644753 Share on other sites More sharing options...
rhysy_boi Member 83 Member For: 18y 9m 20d Gender: Male Location: Perth, WA Posted 12/03/08 08:45 AM Share Posted 12/03/08 08:45 AM I had a vibration at about 85-100km/h that slowly got worse over the end of last year. I put it down to my wheel bearings as my car got in a deep puddle last winter. changed the left one (which was nearly seized) now I still have the vibration just no where near as bad. will change the other wheel bearing in the coming months when I have the money and upgrade my brakes at the same time.Rhys Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-645033 Share on other sites More sharing options...
Eddieb Member 3 Member For: 17y 3m 1d Posted 27/06/08 06:58 AM Share Posted 27/06/08 06:58 AM So whose got the magic wand coz I've got very much the same thing happeing as the others from the beginning of this thread. Had the tyres balanced and checked, rotated and re-balanced. Took the mech/tyre dude for a spin and yep still the same.Bought it back and checked for obvious wear, movement anything on front end - zip all looks good.its done 71,000, 6 month old DBA's Ferodo's - doesn't seem brake related but at the same time doing stuff to the wheels makes no diff either.nipped down south and after an hour of shudder I was ready to throw a match !!any good news from someone whose had this? Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-698998 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 10d Gender: Male Location: Brisbane Posted 27/06/08 08:00 AM Share Posted 27/06/08 08:00 AM XRTPSI said: Oh no, Chiefs hacked tabs account..OK....will dumb it down a bit for yaThe person that started the thread resolved his problem by purchasing a Pajero.How’s that? Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-699028 Share on other sites More sharing options...
iTec TEAM BA Donating Members 1,755 Member For: 20y 4m 27d Gender: Male Location: North of The Bridge Posted 27/06/08 02:51 PM Share Posted 27/06/08 02:51 PM I have the same problem and have had for a while but it has recently stoped happening for some strange reason (lost my licence for 3 months so car was not driven), its not the brakes or rotors because I changed them, its not the shocks because I have bilsteins and they are still sweet, I have narrowed it down to either a wheel bearing issue or a bush in the front suspension, but given it has stoped happening for no aparent reason its got me stuffed! Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-699211 Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 14/02/09 05:04 AM Share Posted 14/02/09 05:04 AM I'm having this exact same problem with steering wheel shudder from 80 on. I've had the wheels blanced and still no good so I put a set of stock wheels on and it the same . it is driving me up the wall it is going in to get new bearings on monday . Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-822985 Share on other sites More sharing options...
mikeBF2TLS Member 32 Member For: 21y 8m 25d Gender: Male Location: Canberra Posted 14/02/09 08:57 AM Share Posted 14/02/09 08:57 AM Guys,I have had this problem 2twice!The first time apparently one of my brake discs was out of whack, ie despite braking I got no shudder, however it was out of balance somehow replaced in full and then fine. This was after 25,000km's from new, was I frustrated by this time or what, endless drive shaft balances, change of tyres etc.40,000km's later vibration shudder is back. Would you believe it, two mags on the left side of the car were 'out of round'. Somehow I must have hit an all mighty pothole (or took a speed hump to hard), but I had two mags that had slight dents on the inside of each of them. When McGraths in Phillip ACT rang me I just said bull#@%!However with the mags off, no tyres on, on the wheel balancing machine it was pretty obvious. Could not believe it. My mags are the standard 18" ones that come with the BF2. $1,400 later replaced and balanced no vibration-bloody rip off-in hindsight I should have replaced all four with some aftermarket, but have a novated lease so costs were not that bad.Even with one mag out of round you will probably have problems. What sort of metal are they using to get a mag out of round when I could not recall any major pothole? I'm the only driver of the car.Get your tyres off the mags and check either on a wheel balancer for a wobble or just roll on the concrete floor. This may be a solution, its solved my problem! Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-823145 Share on other sites More sharing options...
GCTXR6 Member 295 Member For: 17y 22d Gender: Male Location: CANNINGVALE wa Posted 14/02/09 01:48 PM Share Posted 14/02/09 01:48 PM (edited) guys check your caster rod bushes they are gell filled and when stuffed cause brake shudder, get a mate to watch the front wheel at walking speed then touch the brakes if the wheel moves forward they are stuffed ,pedders do an exchange arm with the new bushes in them made a HUGE difference to mine Edited 14/02/09 01:50 PM by GCTXR6 Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-823364 Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 16/02/09 08:01 AM Share Posted 16/02/09 08:01 AM So the car went in today they did the bearings and put a new steering rack in , it had some play in it . The steering shudder is no more BUT now I get a vibration which goes to my seat and I can see my phone move it hangs off the front screen . F**K F**K F**K I am going to burn this car I had a NA BA auto I did 250.000 km from new and NEVER had sh*t like this. Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-824351 Share on other sites More sharing options...
SAM80R Member 11 Member For: 16y 6m 25d Gender: Male Location: Newcastle Posted 02/03/09 09:32 PM Share Posted 02/03/09 09:32 PM I love this forum. Everytime I have a problem with my car my old man tells me I am imagining things. Then I jump on the forum and there is another dozen people with the same complaint.Anyway I am having this same prob. Had the wheels balanced aligned rotated. And back in there today to get the wheel bearings done. Hopefully this is the noise I hear at bout 70 km/h. I also get a small vibration at 100 km/h but this has only happened since the balance so I am blaming the tyre mob for that. Link to comment https://www.fordxr6turbo.com/forum/topic/32848-front-end-shudder/page/2/#findComment-834146 Share on other sites More sharing options...
