Ninka Donating Members 1,850 Member For: 22y 4m 5d Gender: Male Location: Perth, WA Posted 13/10/03 08:09 AM Share Posted 13/10/03 08:09 AM OK, this is a question for those that have replaced their rotors already.I am about to order slotted disks all round, as well as Bendix Ultimate pads. After replacing this, I was going to put the wheels back on without the black pizza tray dust covers (so I can see what I spent my money on!).I was reading JR's website (he posts here occasionally, mainly on FF) and he said that he had a nightmare of a time getting the wheels off after removing the dust covers. Seemed to get seized on, due to lack of dust cover. Anyone else experience this?Have had the permanent fix from Ford for a couple of weeks now, no good, still shudders. Time to actually fix the problem... No dustcovers, DBA Gold Drilled and Slotted, Bendix Ultimates and NO SHUDDER :D I have cleaned the hub carefully (it was quite rusty) applied some copper grease between the hub and the disc, and also around the center where the wheel fits.Recently removed the front wheels due to the fitting of Bendix Ultimates, and the wheels came of really easily, no problem Only reason the wheel may be a bit tighter after removing the dust plates, is that they actually get squeezed a bit harder over the center bit, as the dust covers are about 1 mm thick. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57001 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 8m 11d Gender: Male Location: NSW Posted 13/10/03 08:17 AM Share Posted 13/10/03 08:17 AM I have 19' wheels and took the dust covers off two days after I got the car, so far I have no problems removing wheels and no brake shudder at 6500km , fingers crossed Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57002 Share on other sites More sharing options...
turb06 Dark Knight Mafia Member No. - 666 Member 3,667 Member For: 22y 2m 3d Location: Toowoomba Posted 13/10/03 10:58 AM Share Posted 13/10/03 10:58 AM Any place that fits brakes to a car or replaces brake pads should be able to order DBA slotted rotors for you. DBA are australias biggest brake manufacturer and chances are your local brake huy deals with them daily any way. A friend at work just had a set of slotted DBA rotors fitted to his VN Senator and they were only $140 each for the rotors, he only got the front done. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57061 Share on other sites More sharing options...
Trumpy What's happening? Lifetime Members 1,605 Member For: 22y 4m 25d Gender: Male Location: Steel City, NSW Posted 13/10/03 11:17 PM Share Posted 13/10/03 11:17 PM Thanks guys.I feel much happier about removing the dust covers now. With any luck I should have the disks and pads replaced on the weekend. Cant wait. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57125 Share on other sites More sharing options...
bloan Member 379 Member For: 21y 9m 21d Gender: Male Location: Melbourne. Posted 14/10/03 04:56 PM Share Posted 14/10/03 04:56 PM Just a thought!? :idea: I am right in asuming that the standard calipers & the calipers used on the Premium brakes are the same except for the blue painted finish????If this is the case, to eliminate the brake shudder issue why couldn't you upgrade to the premium rotors using your exisiting caliper along with any brackets & bolts that were needed to perform this upgrade????The only limiting factor I can see would be cost as I would expect the premium rotor from ford is probably double or even triple that of a DBA gold rotor? Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57303 Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 7m 24d Location: Canberra - ACT Posted 14/10/03 10:27 PM Share Posted 14/10/03 10:27 PM I was thinking along the same lines Bloan. From my understanding the Premium calipers are the exact same spec, but assembled to a finer tolerance and painted. They then mount on additional brackets to take the 330mm discs.I'm fairly sure DBA already has a 330mm preium replaceement disc.So in theory it'd take pads, discs and the brackets to do the conversion. It's something I'd be interested in trying A. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57316 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 1m 14d Gender: Male Location: Darwin NT Posted 15/10/03 01:45 AM Share Posted 15/10/03 01:45 AM So whats this bracket part no. then? Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57353 Share on other sites More sharing options...
Guest dbasteve Guests Posted 15/10/03 02:58 AM Share Posted 15/10/03 02:58 AM Can't get the calipers yet, I've tried. The premium rotor is 32mm thick and the standard is 28mm. It's a different caliper body.We make the Premium rotors for the Police. 325mm x 32mm Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57376 Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 7m 24d Location: Canberra - ACT Posted 15/10/03 07:40 AM Share Posted 15/10/03 07:40 AM Ahhh - yeah that'd blow that plan.... Then again a set of Premium calipers will be cheap in a year or two and genuine used parts Set of DBA discs and w00t! Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57441 Share on other sites More sharing options...
ducatijb Lifetime Members 3,448 Member For: 22y 26d Gender: Male Location: sydney Posted 15/10/03 07:42 AM Share Posted 15/10/03 07:42 AM Can't get the calipers yet, I've tried. The premium rotor is 32mm thick and the standard is 28mm. It's a different caliper body.We make the Premium rotors for the Police. 325mm x 32mm Steve,do you actually work at the Silverwater site??? Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/45/#findComment-57442 Share on other sites More sharing options...
