BRAKE SHUDDER ISSUE
Who is it happening to?
1,278 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Guest dbasteve
  • Guests
  Mals BA XR6T said:
That seems strange, because the warped discs don't seem to happen just by driving around. Maybe they are talking about the handbrake dragging?
I had my discs replaced again. This time I was told that they replaced the whole hub, not just the disc?? I thought the Disc and Hub were one unit. They couldn't be talking about the axle assembly could they?
Anyway, the shudder is gone again, and this time I'll be heating them up ASAP and see if I get shudder or fade, and also make sure it goes away once they cool down!
Mal,
The hub is a separate item that houses the wheel bearings and studs. This is fitted to the stub axle support or upright. The rotor locates on the hub spigot and studs and clamped together with the wheel.
Guest dbasteve
  • Guests
  1axr said:
a nice picture of the 4000 series would have been nice with the picture of the hub steve.
As an Engineer (not a salesman) I try to avoid the cheezey sales tactics on a technical forum. :D :sick:
Here is a link if anyone would like to see/read about the 4000 series.
http://www.dba.com.au/4000series/index.asp
Guest dbasteve
  • Guests
  Tinker said:
I have just been notified that Ford now has found a solution to the brake problem. They believe that the problems have been caused by the pad retaining springs not retracting the pads from the rotor properly which then allows the pad to drag on the rotor causing excessive heat buildup and the subsequent warping of the disc. The new parts should be in next week and will be fitted. Here's hoping that Ford have found the problem. Time will tell !!!
Another piece to the puzzle.... :sick:
  • Member For: 22y 6m 15d
Why would Ford say that they need to replace the whole hub assembly?... does this mean that just replacing your discs may not fix the problem???
Also, if that retaining spring is faulty, is this likely to warp the new discs, be it DBA or original Ford Discs anyway?
Now I'm really worried :sick:
Guest dbasteve
  • Guests
Now I'm really worried :unsure:
Mal,
It is possible the hub was out of tolerance which compounded the problem with the shudder. This may be why it was replaced so early.
A disc rotor won't fix a dodgy pad or caliper if this is the problem....
  • Member For: 22y 2m 16d
9000K'S here no shudder but feel the handbrake is always slightly on especially hear it when close to walls or road dividers
  • Member For: 22y 5m 24d
Does anyone know for sure that the hub and spring is direct cause of the brake shudder that a lot of us have been experiencing with the front rotors.
The reason I ask is I've scheduled to have a sit a BDA rotors fitted next week and I will hold off and get the the hub sorted before I go and replace the rotors. I have a feeling that Ford wont fix the hubs if I install aftermarket rotors.
  • Member For: 22y 4m 24d
Just replace the rotors mate and stop putting yourself threw so much agony.You will not be sorry.Best thing I have done to fix a specific problem.
