matsfgxr6turbo Member 388 Member For: 15y 2m 12d Posted 14/09/13 02:23 PM Share Posted 14/09/13 02:23 PM Oww that sounds painful I had the same shudder in mine I changed discs to dbas and cleaned the hubs up really well and there was still shudder so I checked those bushes and there was heaps of movement in them just got them changed and it steers and stops like new car no vibration or movement throught the steering wheel anymore its made it soo much nicer to drive I can't recommend it enough Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1425023 Share on other sites More sharing options...
gemms61 Member 56 Member For: 14y 24d Gender: Male Location: sydney Posted 18/09/13 08:12 AM Share Posted 18/09/13 08:12 AM Ok, so is it both bushs on the upper arm, and did you replace with Superpro? Sent from my GT-N5120 using Tapatalk 4 Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1426224 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 3m 20d Gender: Not Telling Posted 29/09/13 01:22 AM Share Posted 29/09/13 01:22 AM (edited) Brake booster rebuilt - no shudder at ALL and done about 5000km.Bloody beautiful, Apparantly not enough grease or something was used during assembly of earlier boosters. Brakes feel completely different now much more responsive. Just generally the booster wasn't faulty, but it was defiantly stuffed. My bushes are original and still okay. It'll be getting some harder super pros put in at some point but it doesn't seem to be needed.Car's done 160,000kms. I've seen the service record and brake shudder has been treated alot for my car over it's life :( Edited 29/09/13 01:24 AM by johnxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1428795 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 12d Gender: Male Location: Adelaide Posted 29/09/13 12:53 PM Share Posted 29/09/13 12:53 PM I have really bad shudder under braking. Had the wheel inlighment & balance done and still get a wiggle in the steering wheel could that have something to do with all the shuddering stuffing up the front bushes. Any idea cause still under warranty and will get it fixed before the mods. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1428989 Share on other sites More sharing options...
Soroz New Member 21 Member For: 11y 8m 24d Posted 12/10/13 09:53 PM Share Posted 12/10/13 09:53 PM (edited) Random Brake/Steering Wheel shudder in BA -BF at freeway speeds while not braking is usually caused by an over adjusted front pushrod in the brake booster.If you have already spent money on pads and rotors believing the cause to be DTV or tried wheel balancing & tyres ect.... but have not solved the problem.Have the booster checked. I have seen it happen on over halve a dozen vehicles in the last year or so.Hope this may helpThis sounds like my problem. I get severe shudder anywhere from 60-110km while driving normally. The whole car starts to shake and I can feel it through the steering wheel, I can even see the manual gear stick moving around heaps when it happens. Where would be a good place to get the brake booster checked, a wheel and tyre shop or a mechanic? "back off the rod between the booster and the master cylinder a few turns" Would this be a safe option to try? My car has only 55,000 kms on the clock and its an 05 mk2 manual. Cheers Edited 12/10/13 09:54 PM by Soroz Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1432556 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 05/04/22 08:57 AM Share Posted 05/04/22 08:57 AM I have new dba slotted 355mm t3 rotors and brembo 6 piston calipers with the brembo pads on the front and braided lines all round . I bedded them in by doing 7-8 100kph down to 30kph slow downs. They were going fine but have now developed a shudder. I can only get it to shudder repeatedly by going 50kph and doing light braking to a stop. It gets quite violent if I don't lift off the pedal. If I brake hard it won't do it. Any ideas guys? I have cleaned the abs sensors and the plug on the abs sensor wire. Checked the caliper mounting bolts are tight and checked the front wheels spin freely and the rotors don't bind on the pads. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1711404 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,411 Member For: 17y 7d Gender: Male Location: Melbourne Posted 05/04/22 09:20 AM Share Posted 05/04/22 09:20 AM check for brake disc and hub runout. If you have either or both, that'll be the cause and will need to be flatted out on both to sort it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1711405 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 05/04/22 09:47 AM Share Posted 05/04/22 09:47 AM Ok thanks @k31th Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1711406 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,284 Member For: 10y 2m 19d Gender: Male Location: South Australia Posted 05/04/22 10:42 AM Share Posted 05/04/22 10:42 AM The usual cause for excess runout is just sh*t/rust on the hub. Clean it off with a wire wheel and see if that helps. Hopefully those were gentle stops while bedding in otherwise it would have created a lot of heat, which may have warped the rotor. It's cheap enough to get the rotors faced while on the car so I wouldn't stress too much. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1711407 Share on other sites More sharing options...
Slowxr6t Member 574 Member For: 6y 4m 13d Location: New zealand Posted 11/04/22 08:30 AM Share Posted 11/04/22 08:30 AM @PuffwagonI took car to mechanic today to check out brake shudder problem, they took pads out and put an angled chamfer on the leading edge of the pad, it seems to have fixed it so that's cool. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/151/#findComment-1711488 Share on other sites More sharing options...
