dyates69 Member 19 Member For: 22y 30d Posted 20/10/08 12:20 PM Share Posted 20/10/08 12:20 PM I haven't been here for a while. I never saw if there was an official fix for the brake shudder issue, other than just skimming the discs. Has anyone found a reliable, affordable fix for this? Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-752970 Share on other sites More sharing options...
hafadude Donating Members 245 Member For: 19y 11m 14d Gender: Male Location: Cairns Qld Posted 20/10/08 01:03 PM Share Posted 20/10/08 01:03 PM I was told by a local tuning shop that if I get my brakes done (skimming), the shudder will stop for a while but it WILL come back. At least they were honest about it. They did an excellent job on my car for a service so I respect their opinion. Two of the people who work there have XR6 T's. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-752996 Share on other sites More sharing options...
Pube Member 159 Member For: 17y 11m 14d Gender: Male Location: Sydney, NSW Posted 20/10/08 01:33 PM Share Posted 20/10/08 01:33 PM my BFt brakes were machined at around 40k and the shudder hasnt come back so far at 60k. Id say the fix you are after is replacing the disks with a better quality aftermarket disk. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-753014 Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 3m 5d Gender: Male Location: Dianella, West Oz Posted 20/10/08 03:01 PM Share Posted 20/10/08 03:01 PM AFAIK if you replace the discs with DBA 4000's and a good pad, the shudder should subside...Havent had shudder myself so have not had to replace my disks yet but will be soon anyway.Look in the rotor/DBA/replacement disk threads in the Wheels and Handling subforum, they will tell you what you need. Topics have been posted fairly recently.Hope this answers your Q. Good luck! Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-753040 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 10m 5d Gender: Male Posted 21/10/08 12:47 AM Share Posted 21/10/08 12:47 AM new discs and pads will get rid of it.even just pads seemed to help with it on my car, so perhaps you could get away with a skim and pads? Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-753133 Share on other sites More sharing options...
billy88 Member 15 Member For: 16y 6m 1d Posted 30/10/08 10:53 AM Share Posted 30/10/08 10:53 AM the shudder is caused by the disc being uneven, on its surface, most commonly being warped. warping occurs with excessive heat, if you get the disc machined it will be flat but the disc will stil be warped so it is likly to come back again.Could be just low quality metal used in the discs ??If you feel the shudder in the brake pedal, your rear discs are scrwed, if its in the steering wheel, your front discs are screwed.I would say this would be more common to highway driving because of more force being exerted on the discs at higher speeds, causing more heat, and making it alot more probable to warping.im getting sloted front n back rotors in the comming week so will be interesting on how they hold up Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-759061 Share on other sites More sharing options...
Maximus Member 1,627 Member For: 18y 1m 17d Gender: Male Location: Slip Sliding Away Posted 30/10/08 11:07 AM Share Posted 30/10/08 11:07 AM (edited) billy88 said: I would say this would be more common to highway driving because of more force being exerted on the discs at higher speeds, causing more heat, and making it alot more probable to warping.I would say heavy braking in stop start traffic would do it more than constant highway driving.What happens, I thought, is the disc and pad heats up and when you stop the hot pad sits at one place on the disc and warps that one area.So you do that all the way to work and the discs get HOT SPOTS on it that cause the warping.Driving at 100kph and coming to a complete stop would do the same thing but slowing down from 100-80 and continueing along will cause the disc to uniformly heat up all over and cool down the same way.I stil lthink those stupid dust sheilds cause alot of heat buildup in there so I would start by removing them.I have the PBR brakes on my car and they are awsome. Not Brembo like of course but for spirited driving now and then they piss all over the stockies. Edited 30/10/08 11:07 AM by Maximus Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-759080 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 28d Gender: Male Posted 30/10/08 11:29 AM Share Posted 30/10/08 11:29 AM My experience as followsBA Fairmont. Shudder under normal driving. Discs machined twice. Same thing. Replace front bearing hubs and fixed the problem. Using original discs and pads.VT Commode. THey have a disc shudder problem. Had them machined, replaced disc to slotted rotors DBA and agressive pads in the hope they would keep them true. Still shuddered. Changed front bearing hubs to an aftermarket brand that had just came out. Same DBA discs and pads and no shudder.So if you have a persistant shudder I suggest changing the front bearing hubs. I think these style of bearing hubs have run out issues if not manufactured spot on. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-759109 Share on other sites More sharing options...
DaKing Member 150 Member For: 20y 5m 16d Gender: Male Location: Melbourne Posted 08/11/08 02:32 AM Share Posted 08/11/08 02:32 AM Gents,I have just replaced the front rotors on my '04 T with DBA 4000 Series 6x6 slotted and Bendix Ultimate pads and are very happy so far. A simple job to do and the pedal feels a little more "solid" and less spongy. Stopping power seems to be a bit better too (not yet run in though)I got the rotors and pads from Hi Tek Brakes in Moorabbin with the rotors being $290 for both and $125 for the pads - ask for Cam. Those guys did a great job of looking after me.I will stick with the standard rear rotors and get the Ultimate pads for the rear when needed.RegardsKen Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-764107 Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 19y 1m 8d Gender: Male Location: Freeways Posted 23/11/08 08:35 AM Share Posted 23/11/08 08:35 AM My DBA 4000, fronts 2 months old, back 2 days old, gave me a one off massive shudder on the snowies cruise while braking hard yesterday. The steering wheel nearly fell off. A quick stop to let them cool and they were fine again, though I didnt expect the DBA 4000 series slotted to do this ever.I.B. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/130/#findComment-773552 Share on other sites More sharing options...
