aaronmihe Upstanding Member Member 759 Member For: 21y 9m 19d Location: Canberra - ACT Posted 04/05/05 10:06 PM Share Posted 04/05/05 10:06 PM I've just had the latest fix applied to my car (after a minor shudder was fixed at the 30000km service, I managed to get really bad shudder back within 3000km). The new fix included skimming front and rear rotors and new pads.So far brake feel is OK and actual stopping power much better from high-speeds than ever before. The 'new' fix was released around mid-AprilA. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-249645 Share on other sites More sharing options...
BAXR6T Member 187 Member For: 22y 7m 28d Location: Melbourne Posted 04/05/05 10:59 PM Share Posted 04/05/05 10:59 PM Aaronmihne,This fix was released at the start of the year not April. Look at my post from 11 Jan 2005.So far no shudder back and I agree the brakes feel better but they now squeal at slow speed.Cheers,BAXR6T Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-249661 Share on other sites More sharing options...
drcook Member 752 Member For: 20y 10m 5d Location: leonay Posted 05/05/05 04:05 AM Share Posted 05/05/05 04:05 AM 31k. just slide shudder starting the last month or so. im told by a mechanic at ford that they will get worse. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-249760 Share on other sites More sharing options...
XR6TT Member 69 Member For: 20y 1m 2d Location: VIC Posted 24/05/05 05:54 PM Share Posted 24/05/05 05:54 PM now I know im not alone. the internet is grate! Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-256269 Share on other sites More sharing options...
Guest Dean Turbo Guests Posted 05/07/05 07:24 AM Share Posted 05/07/05 07:24 AM I had the problem at 15000km's pld, it was resolved by Ford, they said it was a shim problem and they also machined the rotors and also said the brake system was on a extended warranty. The car is now 45000km's old with a brake shudder problem again. I have an auto turbo and mainly do city driving, and have noticed its occur on both times when I;m giving the car a hard time with its brakes. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-269806 Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 10m 4d Gender: Male Location: Zombie Birdhouse Posted 05/07/05 07:54 AM Share Posted 05/07/05 07:54 AM Dean Turbo said: I had the problem at 15000km's pld, it was resolved by Ford, they said it was a shim problem and they also machined the rotors and also said the brake system was on a extended warranty. The car is now 45000km's old with a brake shudder problem again. I have an auto turbo and mainly do city driving, and have noticed its occur on both times when I;m giving the car a hard time with its brakes.<{POST_SNAPBACK}>Onya TurboDean for dragging up this one from the archives Best option is to go for a PBR upgrade( same as factory Premiums) PM bcro1 who should be able to help. Should the budget not stretch that far , go for some DBA slotted rotors on the front and some performance pads allround. Should set you back around $700 fitted and will stop better and handle the flogging more than the stock Ford brakes , which as we all know are ohhh and no more shudderbug as well Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-269817 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 4m 22d Posted 11/09/05 12:23 PM Share Posted 11/09/05 12:23 PM Well I had unfortunatly voted that I hadn't had any brake shudder at 20K, but as you can guess it's started on the right front at 26k. I have suspected there has been a rattle caused by the brake pad on that side at about 40-50klm per hr.So I guess as the 30k service is comming up I'll have it fixewd then unless it suddenly gets worse.I've heard various fixes from machining the rotors to shimming the pads, which one has the best results??Colin Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-293070 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 3m 9d Gender: Male Location: Darwin NT Posted 12/09/05 11:16 AM Share Posted 12/09/05 11:16 AM 60,000k's later discs machined 3 times, then replaced been machined once, new pads, my conclusion, stock rotors are not going to cut it for an 1800 kilo auto.And it really disappoints me after spending 50k on a car the manufacturor refuse to address the issue. That being the rotors are to small, IMO. Shimming, different pads, "green" discs is all crap, you stand on em a few times, if not once, they warp.rant off..... Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-293423 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 4m 22d Posted 14/09/05 07:38 AM Share Posted 14/09/05 07:38 AM Looked at pricong of 2 options today.Purchase the PBR performance brake system which replaces front and back rotors, disc pads and braided lines. Cost $1950Purchase DBA 504X rotors for the front. Slotted and cross drilled. Cost $138 each.Now to make the decission.TOO bad Ford don't put decent brakes on the car standard, like Expensive Daewoo have. Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-294090 Share on other sites More sharing options...
rushed6 Member 137 Member For: 19y 10m Gender: Male Location: Victoria Posted 16/09/05 06:28 AM Share Posted 16/09/05 06:28 AM what symptoms does brake shudder show is it when your braking and your steering wheel wobbles pls tell me pm me might be easier Link to comment https://www.fordxr6turbo.com/forum/topic/3284-brake-shudder-issue/page/121/#findComment-294910 Share on other sites More sharing options...
