BRAKE SHUDDER ISSUE
Who is it happening to?
1,278 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Greg Brindley
  • Member For: 21y 9m 28d
I road tested an AU111 XR8 220 for a week culminating in a stack of laps at Winton Raceway. It all went well (apart from running out of brakes a couple of times on Winton's easy on brakes track)
After virtually losing the pedal and suffering significant shake (as one does on the race track), over the day following Winton the brakes returned to normal with no shudder whatsoever.
My 2 cents worth.
Greg Brindley.
  • Member For: 21y 16d
Brake shudder,normally is a result of discs getting warped through usage AND sometimes your wheel bearings wearing a bit.Also wheel balance plays a big part.Hit a big curve and see what I mean ehheh:}
  • FORD FORD FORD
  • Member For: 22y 3m 2d
  vik351 said:
210 kph ,please explain
vik
it was the speed of the vehicle dummy :spoton:
Scotty CCC
  • Member For: 21y 7m 1d
XR6 N/A with standard brakes (but almost every other option under the sun :smilielol:)
I had the shudder, had it machined out at 16,500 (running late for the 15,000 service) by Thomson Ford where I bought the car. However, SINCE the machining, I am experiencing a terrible *squeal* whenever I pull up. Doesn't matter what speed I am / have been doing, the damn brakes squeal each time and it seems to happen on the average break pressure that is applied. It's embarassing. If I break harder or softer than "average", then no squeal...
I've actually had to change the way I drive to rely on engine braking more (which I don't mind, LOVE the manual!) so as I don't spend as much time on the brakes. I like people looking at the car, but because it's Citric Acid in colour with "CITRIC" plates - not because every time I pull up at an intersection it sounds like I'm too tight to change my pads.
Anyway, has anyone else experienced this? I took it back to Thomson Ford where they told me they "skimmed" the discs and the sound went away for about a week but is now back with a vengeance. Now have 22,700 odd k's on the clock and don't know if discs should be machined again or pads replaced or what...? :smilielol:
  • FORD FORD FORD
  vik351 said:
Oh deeeeeer,what was the reason dummy.
vik
Late for an appointment dummy :w00t2:
Scotty CCC
  • FORD FORD FORD
  vik351 said:
You dummy,that is called speeding,you can get naughty boy points for that.
vik
I have an excuse, I'm a Real estate Agent, works everytime
Scotty CCC
