Guest Guests Posted 10/05/04 02:34 AM Share Posted 10/05/04 02:34 AM Ive got QFMs on my l300 4x4 and love them,no dust either(compared to the slug)My grease monkey swears by them.vik Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 24d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 10/05/04 06:57 AM Share Posted 10/05/04 06:57 AM So is the current cheapest fix to have the discs machined and fitted with QFM? pads ?or is the DBA slotted rotors the only real fix? QFM is Queensland Friction Materials, manufactured in Nerang on the Gold Coast. If you contact them on 5596 1099 & they'll tell you of your nearest stockistDBA's on their Pat Malone won't cure the problem without a pad change away from the Ford pads, problem is the OE pads retain to much heat & don't have much in the way of heat dicipation abilityScotty CCC Link to comment Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 6m 26d Gender: Male Location: Adelaide Posted 10/05/04 07:36 AM Share Posted 10/05/04 07:36 AM So is the current cheapest fix to have the discs machined and fitted with QFM? pads ?or is the DBA slotted rotors the only real fix?QFM is Queensland Friction Materials, manufactured in Nerang on the Gold Coast. If you contact them on 5596 1099 & they'll tell you of your nearest stockistDBA's on their Pat Malone won't cure the problem without a pad change away from the Ford pads, problem is the OE pads retain to much heat & don't have much in the way of heat dicipation abilityScotty CCC G'day ktford,Is there only one type of QFM pad for the Ford BA... (std brake system)or are there several different material types... eg street use or track use?If they are a track type performance pad, do they work OK when cold in typical everyday street use?What type did you fit to your car recently. Sounds like you are pretty happy with them.cheerstom Link to comment Share on other sites More sharing options...
turbotom Team Bute Donating Members 1,550 Member For: 21y 6m 26d Gender: Male Location: Adelaide Posted 10/05/04 07:39 AM Share Posted 10/05/04 07:39 AM Ive got QFMs on my l300 4x4 and love them,no dust either(compared to the slug)My grease monkey swears by them.vik Hi Vik,Where did you source the QFM's (for your van) from in Adelaide?cheers Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 24d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 10/05/04 07:39 AM Share Posted 10/05/04 07:39 AM So is the current cheapest fix to have the discs machined and fitted with QFM? pads ?or is the DBA slotted rotors the only real fix?QFM is Queensland Friction Materials, manufactured in Nerang on the Gold Coast. If you contact them on 5596 1099 & they'll tell you of your nearest stockistDBA's on their Pat Malone won't cure the problem without a pad change away from the Ford pads, problem is the OE pads retain to much heat & don't have much in the way of heat dicipation abilityScotty CCC G'day ktford,Is there only one type of QFM pad for the Ford BA... (std brake system)or are there several different material types... eg street use or track use?If they are a track type performance pad, do they work OK when cold in typical everyday street use?What type did you fit to your car recently. Sounds like you are pretty happy with them.cheerstom There are 3 variants, I'm using the cheap taxi job as are most others, Top line is around $90Scotty CCC Link to comment Share on other sites More sharing options...
Guest 56Mainline Guests Posted 11/05/04 10:26 AM Share Posted 11/05/04 10:26 AM Update....@ 15000kms got the shudder on the std brakes, had the on-car machining/new shims installed.Now just passed 30,000km (mostly country driving), & so far, so good...shudder yet to return!If it does return, I'll keep on playing the 'warrenty' game then get the aftermarket jobbies (or trade-in to the next new thang!) Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 24d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 11/05/04 10:36 AM Share Posted 11/05/04 10:36 AM Update....@ 15000kms got the shudder on the std brakes, had the on-car machining/new shims installed.Now just passed 30,000km (mostly country driving), & so far, so good...shudder yet to return!If it does return, I'll keep on playing the 'warrenty' game then get the aftermarket jobbies (or trade-in to the next new thang!) Hey Fiddy6where you been?Scotty CCC Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 8m 29d Gender: Male Location: At the lights, waiting for you. Posted 11/05/04 10:38 AM Share Posted 11/05/04 10:38 AM So is the current cheapest fix to have the discs machined and fitted with QFM? pads ?or is the DBA slotted rotors the only real fix?QFM is Queensland Friction Materials, manufactured in Nerang on the Gold Coast. If you contact them on 5596 1099 & they'll tell you of your nearest stockistDBA's on their Pat Malone won't cure the problem without a pad change away from the Ford pads, problem is the OE pads retain to much heat & don't have much in the way of heat dicipation abilityScotty CCC Scotty, how do you thing the QFM pads would go on a track day. How would they compare to the Ferodo or other similar performance pads. Geea. Link to comment Share on other sites More sharing options...
XRBloke Donating Members 1,219 Member For: 21y 7m 15d Posted 11/05/04 10:40 AM Share Posted 11/05/04 10:40 AM Why doesnt the AU shudder??How did they step backwards from one model to another, my AU is an Auto with around 33,000 kms and not even the hint of brake shudder?? I thought the AU brakes were alright to performance wise even though the BA's are bigger.... Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 10m 24d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 11/05/04 10:44 AM Share Posted 11/05/04 10:44 AM Why doesnt the AU shudder?? They shrudder, you're either not driving hard enough or you've not got enough K's up yet. My series 1 has 140odd k's & will shudder upon requestScotty CCC Link to comment Share on other sites More sharing options...
